Results 1 to 10 of 13
- Sep 2005
- 36
March 15th, 2006 08:33 PM #1guys pls help me naman..
kc po lately, im having problems sa aircon. sa umpisa, ok nman cya, ung usual na lamig, pero later on, nawawala na ung lamig tapos parang fan na lang cya.
pinacheck na namen and sabi nung mechanic, naubos na ung freon kase may leak. so pinalitan na ung pyesang may problem, na charge na ung freon and nalinis na ung aircon. nung pauwi na kame, sobrang lamig na, kala namen ok na, then bigla na namang naging parang fan.
sabi rin kse nung mechanic, may leak daw ung water pump, d ko naman alam kung ano un.. un kaya ung problem? wat might be the other causes?
thanks! hoping for your responses!
March 15th, 2006 09:09 PM #2
if malapit ka sa sm north edsa dahil mo kay mang mario yan... malamang hindi naayos yung leak kaya nawala uli yung lamig ng aircon mo.
Toyota is my choice
- Aug 2005
- 2,063
March 15th, 2006 11:32 PM #3water pump? may connection bah iyun? dapat na check lahat possibilities na maging symptoms na magka ganyan aircon mo tol. kay Manong Mario nlang. search ka ni manong mario dito sa kanyan location.
March 16th, 2006 08:21 AM #4
niloloko ka na lng ng mekaniko na yan di nya nakita talaga trouble, bring it sa mahusay na shop. Try also to consider the electrical side like the thermostat and or the relays minsan dyan talaga problem
March 16th, 2006 08:28 AM #5
yup pa-check mo kay mang mario.. pwede kasing compressor problem din yan, baka nga maluwag na yung shaft seal at may tagas na
- Sep 2005
- 103
March 16th, 2006 11:42 AM #6May leak ang water pump? the hell does a water pump has to do something with ur airconditioning systems problem! kung may leak ang water pump, the engine will overheat kase mauubos ang tubig ng radiator mo!
peace!
- Jun 2005
- 3,774
March 16th, 2006 03:58 PM #7water pump?! ano ba namang klaseng mekaniko yun... halatang gusto lang maka-isa at lumaki bill mo. pag aircon ang mga parts lang naman are compressor, condenser, evaporator, fans, expansion valve, filter drier, mga hoses/tubes pati relays and fuse sa electical. wala naman water pump dun....
anyway, dalhin mo nga kay mang mario. magaling sila dun. they have a thing against replacing parts that are still ok. ayaw daw nila manloko ng tao. mura maningil, masarap kakwentuhan.
OT: nung minsan papagawa ako ng aircon dito sa amin for shaft seal replacement, dami agad gusto palitan ng shop sa amin. estimate agad 3100. dinala ko kay mangmario. ang singil lang sa akin 1400. :D
March 16th, 2006 06:26 PM #8
Same here. Kay Mang Mario na yan. Wag mo na balikan ung mekaniko na nagsabing water pump problema mo.
- Jun 2005
- 153
March 17th, 2006 10:28 AM #9baka compressor clutch, di nag eengage. ganyan ang symptoms nyan, nangyari sa akin, ang lamig tapos nawala, tapos mamaya meron uli pag off tapos start
March 17th, 2006 11:17 AM #10
Niloloko ka ng mekaniko, kung may leak dapat naubos na freon mo't ni minsan di na lalamig iyon. Kay Mang Mario ka na.
