Results 1 to 10 of 11
February 3rd, 2006 02:34 PM #1
ano kaya problema ng compressor ng gen2 paj ko? parang di na ito nag-o-off. sinubukan ko nang ilagay sa extremes yung thermostat ganun pa rin. kapapalit pa lang ng expansion valve. malamig naman kaya lang baka masira agad compressor kasi laging naka-on kaya on long drives I manually turn it off every once in a while.
di tulad ng iba maririnig mo talaga yung on-off cycle nila lalo na pag nakaidle lang.
February 3rd, 2006 03:24 PM #3
i think the wirings are ok else di sya mag-o-on. can you please elaborate? mahina kasi ako sa tech stuff
February 3rd, 2006 03:28 PM #4
yung sakin kasi ganyan din dati. ok yung wirings kaso patay-sindi naman yung compressor. as in every 30 seconds buhay tpos after 30, patay. nung pinacheck ko, grounded wirings ko so pina-re wire ko, nilagyan ng sariling relay tapos kinabit sa electrical ng aircon. ewan ko lang sa experience ng iba. pero sa akin, ok na ngayon...
February 3rd, 2006 03:31 PM #5
probably a busted thermostat, hence the compressor does not disengage
February 3rd, 2006 03:33 PM #6
Originally Posted by BlueBimmer
February 3rd, 2006 03:49 PM #7
the thermostat seems to work fine. pag nasa red region sya mahina ang lamig, pag sa blue mas malamig ang buga. please correct if my assumption is wrong. thanks.
February 3rd, 2006 04:13 PM #9
oo nga sana kaya lang wala pa budget ngayon eh
try ko lang baka kasi meron din similar problem yung iba na pwede DIY.
February 3rd, 2006 11:56 PM #10
Baka hindi maganda airflow sa probe ng thermostat mo. Unfortunately, nasa loob siya ng evap housing. Kakalasin mo to check.
Question nalang is what are these toyota units that uses e-CVT? I only know of Rav4 based on their...
Toyota Hybrid E-CVT transmission fluid
