Page 1 of 2 12 LastLast
Results 1 to 10 of 16
    Feb 2005
    Mga masters, I need your expert opinion.
    My brod-in-law bouht a 1994 Delica Chamonix the other day from Pampanga. While I was test driving it last night, I notice na kpag dehins umaandar yung van, mahina yung aircon (halos wala na nga) pero, once I drive on, lumalamig especially kapag pumalo na ng mga 80+Kph. I told him about my observation pero sabi daw nung pinagkuhanan nya at nung mechanic, normal daw yun for diesel rides, especially kung 2nd hand. Is this true? Yung Delica ko kasi dehins naman ganito. I'm asking kasi 'wawa naman ang utol ko kung palpak yung van na nabili nila.
    One other thing: unlike dun sa Delica ko na electronic na yung thermostat control, dun sa Chamonix nya, eh manual yung pinipihit. Tried adjusting it pero no dice.
    Thanks po mga masters!
    Aug 2003
    baka wala naman FAN sa may condenser...pag mabilis lang talaga magkakaroon ng lamig dahil doon lang talaga bubuga yung hangin sa condenser...
    usually nasa baba ng driver and condenser ng delica
    pa check mo rin yung mga hose for leaks and kung nasa color blue yung temperature baka naman nasa hot...hehehe
    and dalhin mo na sa air con specialist..for leaks and freon
    nangyari na rin sa akin yan....di pala umaandar yung fan ko nasira...yun pina overhaul ko lang yung fan and oks na ulit
    Feb 2005
    Ang suspect ko nga din eh yung fan. Kaya kang, ayaw kong kalikutin kasi baka I'd do more harm than good. Anyway, thanks for the help.
    Feb 2005
    Tama baka fan lang yan. However try this. Rev your engine to 2000 rpm and see if the airconditioner cools. If it does, your compressor is weak. Either you have it overhauled or replaced.
    Aug 2003
    kuha ka ng garden hose tapos basahin mo yung condenser...panigurado lalamig yan hehehe
    pag stable yung auto walang pumapasok na hangin usally mangyayari yan sa mga old cars...basahin mo lang ng fresh water heheh
    May 2004
    magkano delica sa pampanga?
    Feb 2005
    270T ang bili nya 'dun. Chamonix na my crystalite roof. Pangit nga lang ang tyres. Kailangan palitan.
    Baka mahina yung auxiliary fan sa condenser, 270T for a Delica? pagkaalam ko parang nasa 180 to 220T range na lang presyo ngayon niyan ah.
    May 2004
    Quote Originally Posted by nicolodeon
    sa khy trading nya ba kinuha? yung malapit sa ford pampanga.
    Oct 2004
    Space Gear ba sya? AFAIK hanggang 93 lang yung L300 (i might be wrong din not so sure). Sa harap lang ba mahina? Might be fan din lang, pero kung sira yung fan dapat tumataas temp nya from the usual sa akin kasi ganon (L300 exceed) nangyari pumutok pala fuse nung fan (yung nasa harap ng radiator), dalawa ata condenser neto isa yung sa radiator isa yung nasa ibaba ng drivers side (paki correct na lang if im wrong ). Sa tires oks dyan is 235 X 75 parang naliliitan kasi ako dun sa stock nya na 215 eh. HTH
Aircon prob sa Chamonix
