Just wanted to give my thumbs up to Cool Spek a Cordillera Street corner Del Monte Avenue QC.
Yesterday I went to EEB Aire Marketing to have my aircon checked kasi di kayang palamigin cabin kapag maaraw. They said ok raw yung high and low pressure reading kaya I need to come back earlier para ibaba yung compressor and do thorough check. Ok naman raw freon. Based on the symptoms baka black oil that would require compressor change. There might be other causes, but the minimum cost would be 10k, parts and labor, to upwards of 20k. Pinapawisan ako sa laki ng gagastusin.
Luckily I remembered Cool Spek, a shop recommended by my officemate, nagawa yung aircon sa Van niya na hindi magawa-gawa ng ibang shops na binisita niya. Diagnosis kulang sa freon, may leak sa valve at marumi yung dry filter. Dinagdagan freon, hinigpitan ang valve, kung saan kinakabit yung hose for measuring pressure, at nilinis yung dry filter. Ayun, chilly na ulit buga. Total bill is less than 1k, labor and freon. Saved more than 9k of potential expense. Honest at mabait yung may ari, si Anthony. Salamat sir.
Mabilis lang sir, but time flies when you're worried (na baka pareho findings at malaki gastos). Siguro less than 20 minutes, kasi feeling ko wala pa akong 1 hour sa shop nila. Although wala naman kasi binaklas.
Kulang sa Freon, may leak, at marumi yung dry filter (yung mukhang radiator na katabi rin ng radiator sa harap ng kotsel). Mura lang nagastos ko less than 1k.
Came here last Monday holiday Sept 11. Since nawala lamig after a month dun sa pinuntahan ko na shop. Nabasa ko dito about coolspeck. Dinala ko mga 830 am bukas na. 1st customer ako, i looked for Anthony as recommended dito. One thing i noticed, maayos mga tauhan nya kahit 2 lang sila, hands on si Anthony sa mga sasakyan and ang daming suki! Which is a good thing. Na diagnose nila leak, na di nakita nung 2 shops na dinalan ko. (isa na dito Sprint sa banawe, sayang 1k ko karga freon lang daw) Pito, and expansion valve, karga freon. Meron pa mga inayos pero di ko na alam tawag dun hehe By 11 pauwi na ako. Lamig pa din until now. Satisfied customer.
