Results 1 to 7 of 7
    Jun 2010
    am not sure if this is the right category pero here's what i notice and sana someone can give me advice on this. recently i had my oil change, tune up, replace oil seal and o ring, and change timing belt. after lahat magawa. engine sounds and feels better. pero after like a day or two, napansin ko na parang bilis uminit ng makina at parang hirap pag medyo binibilisan ko na.
    gamit ko is coolant(50/50 distilled water). before i had all these change, ang paggamit ko ng coolant is like every two weeks ang refill at napakakonti ng nilalagay ko. it's like my 1 coolant mix(2 liters) is good for 4 months. pero after nun, ambilis maubos ng coolant ko. 2 days after at 1 way lang on my way 2 office halos 1/4 na lang natira sa container saka parang asa 2k rpm/shift pa lang ako hirap na makina. am not sure if this has something to do with those changes kasi radiator ko naman is working A-ok pero it really worries me bigtime. i will make a ff-up on this one prolly this coming saturday(5 more days) sa shop. no choice ako but to wait dahil sa work pero sana anyone can give me advice po on how to go about this one. ride ko pala is an old school honda civic lx.
    Dec 2003
    Did you change your water pump when you changed timing belt? Look into this first. See to it that all hoses are put back properly.
    Jun 2010
    Quote Originally Posted by RustyXIII View Post
    - hinde ako masyado familiar sa parts e. medyo baguhan lang din kasi ako and i don't have the manual on my ride. san po ba makikita yung water pump at anu itsura nya? saka one thing i notice is parang biglang umuugong siya pag medyo mabilis na. hayz.
    Dec 2003
    ^Kung saan nakadugtong yung lower radiator hose mo, andun and water pump. Madali lang makita kung may leaks ka kasi naka-coolant mixture ka, obvious kung saan may green na natuyo.
    May 2004
    Quote Originally Posted by bisolvon View Post
    Sir may problem na po yung cooling system niyo kahit before pa tune up... kasi dapat hindi nag babawas ng coolant ang radiator or even the reserve tank... Base on my experience una pa konti konti lang dag dag then dadami yan... eventually overheat na... happened to me sa Civic ko muntik na mag overheat... the culprit is the radiator may leak sa side... got a fresh surplus radiator(Plastic top) Ever since I never had to top up my radiator or even the reserve... always on Max level... Mag 6 months ng ganoon ang cooling system ko...
    pa check mo ang cooling system mo meron itong leak dapat di halos nagbabawas yan. pa check mo rin ang timing ng sasakyan mo, baka hindi maganda noong nagpalit ng timing belt.
    Aug 2008
    sir, kung s makati area po kayo try nyo pong puntahan ung alter energy system... nasa kamagong po cla 9815 kamagong st. brgy. sanantonio makati look for Francis or Ronald or call 510-4968.
relation of change oil/timing belt and tune up to overheating???
