Page 1 of 2 12 LastLast
Results 1 to 10 of 16
    Apr 2009
    ano magandang coolant? mas ok po ba yung no need to add water? I always see this prestone coolant sa mga stores. baka may iba pang mas ok.
    Mar 2005
    Gamit ko yung Peak Long Life Coolant concentrate. Sa Label niya 5 year or 150,000 miles. Php.1.2++ yung 1 gallon niya. Meron sa True Value or Handyman. Make sure lang to use distilled water pang dilute sakanya.
    Aug 2004
    Prestone should be good enough. Meron din silang pre-mixed na in gallon jugs. No need to add water.
    Apr 2015
    Try Pro99. Had it used sa Ford lynx ko. No problems naman. As long as tama yung timpla. 50-50.
    i use any brand, as long as the liquid is of the same color as mine.
    Just get the pre-mixed type para wala ng hula-hula
    Oct 2009
    I've been using Prestone for the longest time. Wala namang naging problema sa naging mga sasakyan namin.
    Apr 2009
    how many liters ba kelangan ilagay sa radiator lets say if im going to use the pre mix coolant?
    Apr 2009
    that depends on what car you have. I use toyota OEM coolant in my car
    Aug 2012
    Quote Originally Posted by bail View Post
    Depends sa size ng radiator. Nakalagay sa user manual kung ilan liters ng coolant ang kailangan ng kotse mo. Example, 4.6L for Toyota Yaris. This means you need 4.6L pre-mixed coolant.
please recommend a coolant
