hindi ako ganun ka well versed sa airconditioning system ng sasakyan pero this is what i have gleamed from decades owning cars.
some vehicles benefit from an additional aux fan. case in point nagkaroon kami ng gasoline l300 1990. that thing almost overheats in standstill traffic and the airconditioning feels naka fan na lang. the diesel l300 did not suffer from those problems. however it is 2022 i refuse to believe may mga modern cars pa designed with such an inadequate cooling system. so that's then.
if you current vehicle has an auxiliary electric fan check that it is still indeed in working condition. noon nagkamali na ako akala ko umaandar pa siya but busted na pala. the only reason it was spinning kasi nahihigop ng radiator from the other side. also check that mayroon pang silicone oil yung magnetic clutch fan mo if your vehicle has one. either way the symptoms you describe does indicate a failed fan or two.
Thanks. Time to have the AC system checked up.
