Page 1 of 2 12 LastLast
Results 1 to 20 of 23
    Sep 2005
    tulong naman mga master, i just had my car, a 95 corolla top over hauled and replaced my radiator with a new one. but after less than a month, naging palyado ang takbo ng auto ko, yung tipong parang isa sa mga spark plug hindi nag tratrabaho. furthermore, nag over heat siya palagi.
    i returned it to the shop and they tightened the bolts of my cylinder head with a torque wrench and change all my sparkplugs. a week later, palyado na naman ang takbo ng auto ko and balik over heat na naman.
    ngayon, palagi na akong nag re-refill ng radiator ko at least once a day and palyado pa rin ang takbo, although pag takbo ng auto, medyo nawawala na ang palyado, pero grabe pa rin and over heating.
    some meachanics are suggesting to again replace the head gasket pero takot na ako eh.
    want to ask you guys first before i decide. thank you po. san matulungan nyo ako.
    nyay, mukang sablay pagkaoverhaul pre...
    lipat ka na sa ibang mekaniko tol...
    check your head gasket. could be damage due to overtightening or is really damage in the first place.
    Nov 2003
    if your plugs are fouling, you'll need to replace the valve seals too.
    that and have the head checked for warpage. then replace the head gasket and you should be fine.
    Aug 2005
    parang hindi maayos pagka overhaul...
    Jan 2004
    Balik mo yan back job yan pare.
    Quote Originally Posted by the_wildthing
    according sa post ng thread starter mukhang pabalik-balik na sya e. mukhang it's time na talaga na lumipat ng ibang mekaniko.
    May 2005
    back job nga iyan ,dapat kausapin niya mabuti ang owner ng shop kung di kaya ng mekaniko nila .sila mag pagawa sa ibang shop ,dapat may warranty ang gawa nila.kasi mas lalaki gastos ng thread starter kung sia mag hahanap ng bagong shop
    OT magkano na ba mag pa Overhaul ng engine like 4K Toyota engine at saan na din maganda pagawa?
    naka arbor kasi ako ng isa .gagawin ko lang service sa Province namin
    mukhang hindi talaga ayos pag kaka gawa.. bago radiator dapat ok na cooling nyan. baka nga sablay pag kabit nila ng gasket. wag mo na intayin mag halo ang Oil and water
    Sep 2005
    bro, bago ang head gasket nito, valve seal at pina machine shop ko pa ang cylinder block nito.
    mausok b bro? ganyan din kse prob ng corolla 90 ko dati eh. pina top overhaul ko na, overhaul din radiator, pero nag ooverheat p din at namamalya. may sira n daw piston ring.. bka ganun din sakit ng auto mo bro. sakit talaga sa ulo pag ganyan sira ng auto...
    Jan 2004
    Pero ang oil mo hindi nababawasan? Anong kulay ng usok galing sa tambutso?
    Sep 2005
    Kung ako sa iyo lilipat na ako ng mekaniko. dalahin mo kay speedyfix auto mo......
    san ba ang location mo jeffishot
    Aug 2005
    Parang pababalik na yan ah.. Higopin pera mo dyan.. cheap lng yun repair tapos pa BALIK2x ka lng eh parang mahal na din.. dapat reputable shop kahit medyo mahal basta wlang hastle.. hayy nko Siraniko talaga.. Tol taga san kba? Kami nlang taga TSIKOT mag re-refer sayo..Good LUCK
    Aug 2005
    ahhh.. SO bago pla yun mga pinalitan.. maayos bah ang pagkagawa? kung hindi eh talagang pa balik2x lng yan..
    Nov 2003
    when the head is out pwede mo na makita yung rings kung malaki na alog/play. kung ganun, dapat di na nila binuo yung makina and they advised you to replace those as well. nagiging doble gastos and sakit sa ulo lang if you don't fix it correctly the first time.
    Sep 2005
    Mga bro, i had it checked with a second mechanic and he advised me to have a CRACK TEST. will this do any good before any more repair be done?
    Nov 2003
    crack testing will check if the head is repairable or not. kung may crack na, kiss it goodbye.
    Sep 2005
    any other reason that may cause my problem?
Over Heat + Palyado
