Results 1 to 3 of 3
    Sep 2008
    Mga sirs, lately po e napapansin kong di mag-automatic shut off yung mga fans ng radiators ko, related po kaya ito dun sa leak sa compressor? TIA.
    It is related because the fan is linked to the A/C system. It is possible the freon level is low so it is not reaching the cut-off pressure to turn off the compressor.
    In normal operation, the compressor should turn off with the fan when the correct freon pressure is reached.
    Sep 2008
    In normal operation, the compressor should turn off with the fan when the correct freon pressure it reached.
    Thanks po sir!
AC question
