Results 21 to 27 of 27
January 28th, 2019 09:29 AM #21
Every 1-2 years: Have evaporated cleaned, refrigerant (Freon) checked and / or refilled, compressor oil checked and / or refilled, compressor o-rings replaced ...
- 54,317
January 28th, 2019 10:03 AM #22
- Feb 2019
- 58
March 27th, 2019 04:53 AM #232) I tried turning the fan to level 2, hindi nagrorotate both fans. I tried switching on the A/C knob, and then yung radiator fan lang ang umandar. Is this normal?
Audacity Find My iPhone Origin
- Feb 2013
- 32
May 4th, 2019 07:06 AM #24Thanks. So apparently, nagpaAC cleaning na lang ako (air filter replacing/cleaning) - costed me about 2-3k. Lumamig naman siya, umaabot sa 2nd row pero mukhang malabo na umabot sa 3rd row.
It was good - was able to test it during the extreme summer hot weather. After 2-3 weeks though, I noticed something:
1) Lumalamig pa rin naman pero humina yung fan (or pagblow ng air)
2) Minsan sobrang hina ng pagblow ng air sa loob pero if you touch the AC vents, malamig siya. Yung feeling is nagbblow siya ng cold air pero yung sound parang sa loob ng vent siya bumubuga (kumbaga hindi makapasok sa loob ng car). Malamig naman pero yun nga, hindi aabot sa driver's seat.
3) Paglabas ko, there are water leaks pero parang hindi usual kasi nakikita ko rin sa ibang areas (see 2 videos). Usually isang area lang naman lumalabas yung AC water diba? I noticed na merong ibang areas sa ilalim ng car na basa rin - unless normal talaga dahil mainit and nakamax temp yung setting ng AC?
4) Mukhang wala naman leak sa coolant so I should be safe but you can enlighten me if I missed something.
5) Sometimes, pinapatay ko yung makina na lang muna. Pag-on ko, malakas ulit yung AC then #2-#3 happen again after sometime (siguro mga 30-40 mins after)
Video Links:
Minsan napapaisip ako na magpainstall na lang nung aircon na kinakabit sa 2nd row (yung mga gamit minsan sa public FX). Safe and okay ba yun?
Thanks in advance!
May 4th, 2019 07:15 AM #25
- Feb 2013
- 32
May 4th, 2019 04:11 PM #26what/how do you think this can be fixed? mahal kaya or simple lang?
is it the same as this one? Car AC Lines Freezing Up? Here's What You Can Do About It
May 4th, 2019 07:00 PM #27
Design & Dimensions: Exterior Refresh> Builds on current Kodo design with sharper, more...
2026 Mazda CX-5
