Results 1 to 8 of 8
- Aug 2010
- 86
August 29th, 2013 09:04 AM #1Mga Sirs, Yun CRV 03 dito sa house,pag ON ng aircon from start, may parang tunog ng roleta sa AC blower. Mawawala din after a while. Siguro nagpapaalam na yung blower motor. Aside from OEM, may makukuha ba na replacement like circuit brand para sa fan motor na ito?
Thanks and more power.
- Jan 2011
- 242
August 29th, 2013 09:36 AM #2Im no expert sir. May chance din po that there is just some sort of debris or dirt in the fan blades which is making the noise.
- Jun 2010
- 321
August 29th, 2013 10:18 AM #3minsan kulang lang sa grease/lubrication , ganyan din ac blower ng eg ko dati, baklas ko lang then sprayed w40 sa may bearing at shaft nawala ang grinding noise.
- Aug 2010
- 86
- Jul 2010
- 570
- Aug 2010
- 86
September 1st, 2013 12:20 AM #7Yes sirs, napalitan na yung motor, surplus nga lang. Stuck na yung bearing. Isa pa pala, bago nito nabanggit ng wife ko na minsan pag switch nya ng blower knob, wala daw buga sa mga vents. Kaya pinatay at ni-restart, OK naman. Ngayon noong pinalitan ng motor, ayaw din mag-ON yung motor. Pero kapag nagrekta ng supply meron naman. Ayun, goodbye na rin pala ng resistor block. Sabi nila, after effect na lang daw na nasira yung resistor block kasi sa motor condition. Pero known naman na may issues yung resistor-transistor block ng Honda model na ito AFAIK.
September 2nd, 2013 10:40 AM #8
Naalala ko iyong 2013 SJ Forester ng relative namin. FMC change siya ng time na nakuha sa casa. ...
Yaris Cross 1.5 S HEV CVT vs BYD Sealion 6 DM-i
