Results 11 to 15 of 15
April 5th, 2006 09:43 AM #11
nag babawas ang tubig? di ba talaga naman nag eexpand ang tubig pag mainit pumupunta sa reservoir yun pero dapat babalik pag cool down baka sira na yung hose mo papuntang reservoir
April 5th, 2006 01:28 PM #12
Originally Posted by fierari
oo nga sir, napansin ko kc ung reservoir parang puno na.cge sir try ko chk ung hose mukang d nga bumabalik ung tubig from reservoir to radiator.
Anyway, ok kya na i upgrade ko ung radiator ko into 3 rows? Kinakabahan 2loy ako bka itirik ako neto sa saturday kc bakasyon ako 1 wik sa bicol...layo p nman ng byahe ko.and ask ko din sana, last saturday kc nag drain ako ng radiator and lagay ako coolant (50/50 with distilled) 3 liters ung lagay ko, meaning b nun 2 rows sya? ano b capacity ng 3 rows na radiator? pls advice tnx in advance
April 5th, 2006 02:47 PM #13
sir, check also ur radiator cap. its possible that when the a/c is on the temp gets higher and the rad cap cant withstand the pressure so the water is dislodged out (not only to the reservoir). check the gasket, better yet, buy a new cap. mtcw.
April 5th, 2006 04:11 PM #14
tnx conzky try ko din...palitan, pare pareho lang ba size ng radiator cap?
April 5th, 2006 06:39 PM #15
mali yta nabili ko n cap d sya fit sa radiator ko dba meron 2 ung specs?
ung dati nya kc 0.9kg/cm lang nkikita ko.
ano kya fit para sa liteace?
