Page 9 of 15 FirstFirst ... 5678910111213 ... LastLast
Results 81 to 90 of 143
    #81
    tanong lang po sana kung avalable pa sa concorde yung Pylon's Strip-It?
    thanks!
    #82
    add ko lang,
    bought this in Ace hardware last week. used it on all the windows and windshield, effective naman. tanggal din ang judder ng wiper.
    Sep 2005
    #83
    Quote Originally Posted by tibo_3rd View Post
    add ko lang,
    wow! mukhang ok to ah...mura pa.
    Nov 2006
    #84
    Quote Originally Posted by x-wind View Post
    sa mga taga south na naghahanap ng pylon strip its available na sa concorde south mall sa first row sa left sde sya sa baba ng mga wiper dami sila stock.
    Hehehe... Rakenrol... Baka me location map ka ng item sir para mas complete... :grin2::grin2::grin2::grin2:
    Jan 2008
    #85
    mga sir, i use auto magic wire wheel cleaner, it's actually an acid so you have to be very careful using it as it will really fade your paint if you get it on the body.
    you just have to make sure your glass is clean and cold( hot glass will fade if you use this!!), put eough of the solution on a cleaning cloth and start rubbing away!!! just don't forget to wear rubber gloves...and don't over rub any one area!!
    the solution can be bought at citimotors or wherever there are auto magic cleaning solutions
    Jan 2008
    #86
    Quote Originally Posted by puroy View Post
    the no streak is okay to a certain point, but it can not remove the really heavy and old water marks, i use this as my maintenance glass cleaner. i clean my glass 1 a year with a mild acid to remove heavy water marks
    #87
    saken WD40 lang. once a month treatment. ayun solve!
    Aug 2007
    #88
    Quote Originally Posted by DRAG_LORD View Post
    talaga ok yan? Mahirap din i-rub?
    #89
    ah makikisingit lang,, how about mild windsheild scratches, papano kaya to mareremedyohan?
    #90
    kita ko to sa robinsons handyman and true value. ACDELCO Windshield Shiner. haven't tried it yet. linis ko muna car ko then try ko. pang frequent maintenance lang siguro ito.
cannot remove water marks sa windshield...
