Results 1 to 8 of 8
- Dec 2006
- 59
January 31st, 2011 05:49 AM #1mge sir's pa help naman kasi napansin ko may natunog yung kotse ko pag lumiliko ako left/right nag "tok tok" ano kaya possible sira nito? sabi kasi nung 1 kilala ko baka knuckle bearing daw. ano sa tingin nyo sira? and magkano estimate abutin gastos ko? thanks
January 31st, 2011 08:27 AM #2
if the "tok-tok sound is relative to your car's speed, it might be your CV joint. It could been in need of replacement.
The CV joint (constant velocity joint) is the universal joints at your front axels. Usually they are covered in a rubber boot with grease inside. But due to use and age, the rubber boot may have ripped open and grease leaked out or dirty water have gone inside. Either way, it will cause accelerated wear & tear of the CV joint.
Replacing it is not that expensive and should take under two hours to finish at the repair shop or gasoline service station.
January 31st, 2011 08:50 AM #3
TS ganyan din problem samin.. try mo muna pacheck sa mekaniko mo yung CV joint both left and right kasi kami nagpalit sa isang side lang(R) pero sira narin pala sa left kaya bumalik yung TOK TOK sound pag naliko..
*GH...
question mga FWD car lang ba may CV joint?..
CV joint din kaya yung pag fullturn ako parang kumakadyot yung car den sabay may tutunog na "toktok"?...
- Dec 2006
- 59
February 1st, 2011 12:11 AM #4*ghosthunter: CV joint ba = knuckle bearing? how much estimate magastos ko? btw toyota corolla lovelife ang kotse ko. thanks sa pag reply.
*emj21: nung nagpalit ka magkano damage parts & labor? thanks
February 1st, 2011 09:22 AM #5
2600 cvjoint left replacement lang madugo ang OEM, 800 labor sa harap lang ng bahay namin ginawa, kakilala namin mekaniko... CRV first gen pala car baka sa mga Toyota mas mura..
sabihin mo lang sa marunong na mekaniko check nila CV joint alam na nila diagnose yan kung sira naba o hindi..
February 1st, 2011 10:06 AM #6
ganyan din naging problema ng small body ko ae92/4af engine, tok-tok pag liko sa kaliwa
nung tiningnan ng mekaniko, cv-joint nga ang problema, nasira na yung cv boot at halos matuyo na yung grasa, kaya no choice kungdi magpalit ng cv joint yung inner... lumuwag na yung pinaka housing kaya pag liko tumutok-tok, actually yung mga ngipin pala yun na hindi na masyado kumakagat dahil maluwag na housing...
sa pagkakatanda ko nasa 500-600 yata price nun, tapos labor is 300 pesos, plus dagdag grasa worth 50 pesos, ayos!
- Dec 2006
- 59
February 10th, 2011 10:31 PM #7salamat sa mga nag reply. CV joint replaced. inabot ako ng 3k parts & labor. thanks tsikot. more power!
March 11th, 2011 09:41 PM #8
same din ganyan nangyari sa apv ko. and ang problem is ung steering column nman it costs me 5k genuine parts sa suzuki
New app update for Gcash. It locks the Gcash account to the particular device you are using so you...
National ID Law
