Quote Originally Posted by slowrockmusic View Post
[SIZE=2]sir asking lang po when engine is cold the shifting is ok,but when car is use 30 minute driving the A/T won't shift in 2nd gear won't **** in 4th gear [/SIZE]its steady on 3rd gear when i try to full speed the RPM is 5000 rpm max speed 100kps only why my car won't shift in low gear and high gear?
your problems seems to be temperature related. has the Malfunction Indicator Light illuminated? there could be a problem with the coolant temperature sensor. it sounds like it is shifting at default. this will not enable the overdrive.
