Results 1 to 10 of 10
- Jul 2009
- 3,604
September 1st, 2016 01:49 PM #1Hello all,
Patanong lang, baka may nakakakaalam hehe.
The clutch pedal is squeaking on our car, a 2009 Civic (FD).
I have tried lubricating the master cylinder behind the pedal with lithium grease, pero parang hindi na kinakaya, and the sound now seems to be coming from behind the firewall.
Nabasa ko that the issue may now be the clutch fork, which may need lubricating. Kaya ba itong iabot and ilubricate without a lifter? Was checking youtube videos and other forums and wala akong nakitang makakasagot ng tanong na ito hehe.
Any input appreciated. TY!
- Apr 2009
- 536
September 1st, 2016 02:30 PM #2
it happened to my ride I also did lubricate everything that I think is connected to the clutch.
it happens during rainy season. at first what i did is look for the linkages near or connected to the
Secondary clutch. you have to have someone step on the clutch so you can see what moves from
below the engine. then i put grease and the major squeaks was gone.
Another thing that i observed was when i replaced my secondary clutch. totally the squeaks was gone.
Maybe what you can do( i dont know if there's linkages on a Civic) bleed the old fluid and have a
fresh brake fluid. have a mechanic inspect your secondary clutch and bleed the fluid from the cylinder.
- Jul 2009
- 3,604
September 1st, 2016 04:24 PM #3Yes, madalas nangyayari lang yan tuwing rainy season. Pag hindi naman maulan, tahimik and maganda operation ng clutch.
Kaya bang ilubricate yung mga yan from the engine bay? Or kailangan pa idaan sa ilalim/i-lifter or something?
Replacing the clutch master/slave cylinders are also an option kaso halos 10K yata yun pag original part. Not worth it just for the squeak unless may iba pang problema na hehe.
- Oct 2009
- 2,271
September 2nd, 2016 01:10 PM #4ung push rod ang nilalagyan ng grease.kasi un ung nagtutulak.metal to metal.kung sa pedal naman ung pinaka rod din na naka kabit dun sa pedal arm.palibutan mo ng grasa.
- Apr 2009
- 536
September 2nd, 2016 05:39 PM #5
I suggest pa inspect lang especially the secondary clutch if may fluid moisture na. if okay pa pa bleed mo and better lagyan ng kaunting grease sa gilid ng rubber cap ng cylinder. sa tingin ko lang sa tagal
ng fluid na hindi na bleed nawawala lubrication. ako sariling sikap lang ginagawa ko pinapalitan ko lang
fluid sa reservoir. sometimes pag too much rain may squeak na kaunti.
- Apr 2009
- 536
September 2nd, 2016 05:46 PM #6To Add. sa experience ko nung from time to time may squeak. pina inspect ko yung secondary clutch ko
may kauting moisture na sa rubber housing. kahit one year pa lang yung replacement clutch cylinder
pinapalitan ko na, i replaced it with Seiken , i believe quality its close to OEM part. pag kabit lumambot
clutch ko and nawala squeks. its a lesson for me kasi one time nasiraan ako ng clutch operating buti
nakauwi pa ako kaya ayaw ko na take risk. mura lang naman yang part na yan.
- Sep 2016
- 50
September 22nd, 2016 08:31 AM #7I have this on my 08' Hilux as well. Squeaky clutch, deep clutch, hard to press clutch pedal, the feeling that there is sand whenever you engage the clutch pedal, etc. I will have it checked and service --- probably be getting a new master cylinder, clutch lining, pressure plate, and etc. Hope not too many so as not to be too expensive haha! But I will post updates here regarding the repair and the improvements
- Sep 2016
- 50
March 21st, 2017 07:28 PM #8Super late update lang po mga boss. Nawala na yung squeaky feel sa clutch ko.
I had it serviced sa casa few weeks ago. Nagpapalit ako ng --- Release bearing and pilot bearing + Clutch assembly cleaning. So far, okay na.
March 21st, 2017 07:49 PM #9
how much wallet damage?
- Jan 2013
- 178
March 22nd, 2017 09:29 AM #10Yung sakin din squeaky na at matigas. Ganyan din nirecommend ng casa palit lahat. So hindi ako naniwala. Nag diy lang ako, ininjectionan ko lang ng oil yung cable, ayun ok na. good as new
Sensing a hint of weakening on our 6yr old Thai Pana DIN74, went to the distributor to have it...
