Results 11 to 16 of 16
- Jul 2016
- 939
March 4th, 2017 10:28 AM #11Volkswagen Clutch Noise (chirp / Hoot) - YouTube
Honda Civic First Gear Clutch Noise-8th Gen Civic Si - YouTube
You can easily check if it came from belts, just do a quick hard rev sa engine. If its the belts, it will sound.
- Feb 2017
- 28
March 4th, 2017 11:41 AM #12Thanks for all the input guys.
Actually i was slowly releasing the clutch, as it was downhill- trying to engine break, when i heard the squeeking sound. I pressed the clutch again and sound is gone then slowly releasing it again and the sound again just then i realized and notice that i was still in reverse. After that i shifted to first gear and car drived then as normally. I will have the car check soon maybe i'll have all your inputs to be check by mechanic. By the way the pambelt is new also.
- 52,731
March 4th, 2017 12:31 PM #13some "pambelts" need a bedding-in period, po, after which, belt tension is re-adjusted if necessary. not all cars have idler pulley.
- Jan 2010
- 283
- Oct 2009
- 2,271
March 4th, 2017 01:36 PM #15okey lang yan.ganyan ginagawa dati ng tiyuhin ko dati sa baler nung nag byabyahe pa kami ng mga troso.pag pababa at medyo madulas ang kalsada naka shift siya ng reverse..
- Feb 2017
- 28
IIRC they're with AVID. The reported numbers in the TG article are from CAMPI.
Car Sales Data (2024)
