Results 11 to 18 of 18
August 15th, 2014 12:41 AM #11
hindi naman kaya isa sa mga tensioner bearings mo yan?
80,000 kms na kamo so malapit na yan mag change timing belt kaya damay tensioner bearing nun...
meron din tensioner bearing for aircon pero depende yan sa configuration ng ride mo...Last edited by jodski; August 15th, 2014 at 12:45 AM. Reason: Added more details
- Nov 2009
- 3,484
August 15th, 2014 12:56 AM #12M13A afaik is chain driven.. Whine should go with RPM at any gear, TS described it to occur only at 4th & 5th gear.
August 15th, 2014 01:02 AM #13
- Jul 2011
- 1,711
August 15th, 2014 06:11 AM #14
- Mar 2004
- 434
- Mar 2004
- 434
August 15th, 2014 09:37 AM #16
- Mar 2004
- 434
August 17th, 2014 01:03 PM #17update--
lifted the rear of the car and put her on blocks.
shifted from 1 to 5. sound starts at 40kph on 4th and 5th. slight sound on 3rd at 40kph. didnt try at 1st and 2nd as the engine noise is higher than what i can hear. plus i think its rather dangerous to do on those gears.
the noise happens when i lift off the throttle and push back in.
the sound is defintely on the tranny not on the transfer case.
so what other component from the tranny that could emit such noise?
will try to change tranny fluid. hopefully it helps.
- Mar 2004
- 434
September 1st, 2014 12:21 PM #18update==
sent it again to the talyer and had it lifted. as the shifting was getting hard.
conclusion. short on tranny fluid. it was topped off. and now good.
on a side note. changed to yokohama geolander at. what a difference in ride from the stock tires.
Thank you!
