Results 31 to 40 of 45
March 9th, 2009 11:13 AM #32
sir update ko lang yung sa car ko pina tune up ko palit sila ng clutch disc ,pressure plate, release bearing palit din ng fuel filter,ok na sya pag bumagal d na sya na kadyot o jerking nga....ang napansin ko naman ngayon ung pag apak ko nang kunti sa gasolina at kunti apak parang nakadyot ng kunti pero mabagal lang yun..... ano po kaya ito?.........any one help po...yun po palang fuel filter ko nun nalinisan dami dumi nakuha ung mekaniko.....kaya pinalitan ko na lang ng bago dami po buhagin ata un...posible po kaya sa gas pedal cable ko problema ?
March 10th, 2009 06:05 AM #33
March 10th, 2009 08:58 PM #34
just give it a slightly full press on the accelerator with the perfect combination on the clutch release, pag ayaw pa din kahit anung technique. try mo pa check yung spring and components ng clutch and accelerator pedal baka kinakalawang na, might need a WD-40 remedy.
March 11th, 2009 08:25 AM #35
- 168
March 15th, 2009 11:28 PM #37
sir ano po ung re surface ng flywheel bali anong gagawin po dun may papalitan po ba na pyesa?magkano po kaya magagastos ko kung sakaling ipagawa ko un any idea po ba?
March 15th, 2009 11:28 PM #38
sir ano po ung re surface ng flywheel bali anong gagawin po dun may papalitan po ba na pyesa?magkano po kaya magagastos ko kung sakaling ipagawa ko un any idea po ba? senya
March 16th, 2009 08:41 AM #39
March 16th, 2009 08:44 AM #40
