Results 11 to 20 of 45
- Nov 2006
- 299
December 13th, 2008 06:06 PM #11
- Jan 2008
- 4,726
December 13th, 2008 08:43 PM #13natawa naman ako dito sa ayuda na ito...
jerking or sa tagalog eh kumakadyot... hindi ayuda, kadyot dapat
kumakadyot kadyot yan kotse mo.. possible cause are the following
> too much slack or too tight accelerator cable
> worn out transmission and engine supports causing the engine to move violently when slowing down at low gear (engine breaking), once the speed is around 5-10kph
> worn out clutch disc
> worn out CV joints or axle
> worst case is the transmission have too much backlash causing jerking
December 14th, 2008 09:59 AM #14
Thank goodness for the clarifications, i was beginning to think i needed to google this ayuda thing already hehehe. Actually i have been experiencing the same thing on my car, MT as well, corolla 90. I did, for a time, begin to believe that the problem of "jerking" was caused by my manner of driving, but then i realized that it would make any sense, since matagal-tagal ko na rin dina-drive ung auto ko pero bakit lately lang nag start ung problem. So i had my engine supports replced, and adjusted the idling as well. Ung tranny support ndi pa kasi alaws nako breads. pero tama si sir yapoy, have your auto checked asap. it only gets worse, believe me (i'm referring to the "ayuda"-ing)
December 14th, 2008 10:22 AM #15
sir salamat po sa mga advice nyo siguro nga kailangan ko e pa check sa mechanic yong car magkano po kaya magagastos ko kng ipapa ayos ko ung jerking ng car ko para mawala na ito...sa estimate lng po ninyo? thanks...
December 14th, 2008 12:07 PM #16
ang ibig sabihin nya pag nag 1st gear tapos tatakbo ng 20kph hahayaan nya daw ubusin ang takbo ng 1st gear 20kph going down then pag nasa 5kph na daw wala naman sya tinatapakan gas pedal bigla daw aayuda ang sasakyan at tatakbo ulit tama ba explanation ko sir?
diba dapat mga peeps pag naubos ang takbo guguldol na ang sasakyan at mamatay ang engine?
- Jan 2008
- 4,726
December 14th, 2008 12:38 PM #17bago naman word guguldol... ayuda and kadyot....
well normally at 1st gear say you are running at 20kph and release the accelerator your car should slow down without jerking and still maintain the low speed without stepping on the brakes (at most 5kph just like in a procession)
December 14th, 2008 07:06 PM #18
aga cruz yun nga ung na experience ko sa car ko tama un......ano ba dapat don?tama ba yung ganun sa car di ba dapat hanggang bumagal eh smooth parin sya? help lng po.....
December 14th, 2008 07:10 PM #19
tama ka rin yapoy86 dapat ganun sya di ba pano kaya po?ano po ba dapat don?
December 14th, 2008 07:11 PM #20
john medyo mahirap pero naranasan ko na din yan dati sa corolla XE ko kaso naibenta na wala naman bad eefect sa akin hasle lang pag nag sstroll kayo ng barkada lagi ka naka aalalay sa clutch..
yapoy talagang madami ka mapupulot na salita hahahaha
sabi nga ni yapoy sa tingin ko din baka worn out na ang cable ng gas pedal
The Ten Commandments has been a traditional part of the Holy Week programming on local channels,...
Traffic!
