Results 31 to 39 of 39
March 16th, 2005 10:42 PM #31
mapapansin mo yun pag naka D2 lang. You can shift from D2 to D or to D1 while moving. wag lang R. Dapat full stop ka.
March 17th, 2005 12:35 AM #32
you can shift from "L" or "1" to "2" to "D3" or "D" anytime. it will in no way harm your transmission. in effect, youre telling the transmission to upshift.
- Mar 2005
- 16
March 17th, 2005 02:12 AM #33maraming salamat po. dahil nung nangyari sakin yan naghanap pa ako ng shoulder to stop kasi napansin ko umuusok likod ng starwagon ko yon pala naka D2. mga 70kmlang naman takbo ko.
follow up question:
in normal operations, the gear shifts by itself in sequence.
ngayon kung naka lock ka sa D2 at 60kph at lipat mo sa D, may extra boost ba sya compare to the normal operation? (like in manual tranny)
sorry po sa kakulitan...wala kasing manual tong mga delica e.
thanks
March 17th, 2005 03:09 AM #34
most probably wala, because you're using the same gear ratios through the same torque converter. ang advantage lang ng "sequential manual shifting" na ganyan ay kung hindi pinapaabot ng redline yung transmission in a lower gear (this means that the A/T is poorly designed). but generally, kung i-floor mo yung accelerator, dapat sa redline na din maguupshift yung A/T, which is the same as manually redlining it in D2 and then manually upshifting to third gear. depends on how smart the A/T is though
- Mar 2005
- 16
March 17th, 2005 08:50 AM #35mbt maraming salamat.
hehehe..mukhang hindi ka natutulog chief, bilis mong sumagot.
anyways, more power to you guys.
- Aug 2010
- 14
September 2nd, 2010 05:07 PM #36Mga sir patulong naman po sa inyo ngayon lang ako kasi naka gamit ng automatic im using civic vtis 2002 model po eto po arrangement ng kambyo niya, P-R-N-D-D3-D2. Eto po mga tanong ko.
1. Habang tumatakbo po ang car nasa D po siya pwede po ba y shift ito ng D3 or D2. Ku sakali po pede i shift ano po dapat ang actual speed ng car bago siya dapat y shift from D3. Paturo naman po ang use ng D3 at D2.. Pasensya na po at tnx marami
September 2nd, 2010 05:49 PM #37
[SIZE="4"]REMINDER: do not post messages in SMS/TXT shortcut format.
Read the RULES.
Ignorance is NOT an excuse.
Repeated offenses will lead to banning.[/SIZE]
September 8th, 2010 09:40 AM #38
Pwede, but only if necessary, e.g., you need to stop/slow down immediately -- D3/D2 will serve as engine-brake.
I'm not sure kung ano ang max. speed na pwedeng i-shift down ang car mo from D to D3 without causing damage pero siguro 80KPH is a safe speed for D3, and 40 for D2.
[SIZE=1]151/3,874(3,851+23 missing posts)[/SIZE]
September 8th, 2010 09:40 AM #39
It's looking like Shopee / Lazada / AliExpress have a long list of available parts for various...
2024 Manila International Auto Show APRIL 4-7,...
