Results 31 to 40 of 57
November 10th, 2005 10:19 PM #31
so pag naka O/D mode tipong katumbas lang ng 3rd gear maximum? i dont use O/D feeling ko kasi mas maaksaya sa gas so basta naka D lang ako ok naman by the way im driving rav4, O/D ba counterpart ng D3, sa honda me D3, D4 diba
November 10th, 2005 10:29 PM #32
kapag meron O/D button ang A/T mo, meron indicator sa instrument panel kung naka-OFF ang O/D.
kapag naka-ON ang O/D, hindi naka ilaw ang indicator.
this is another misconception for most users of A/T cars. kapag pinindot yung O/D button, akala ng nakararami, yun ang ON, pero kung titignan sa indicator sa instrument panel, ang nakasulat O/D OFF.
cutedoc, i believe you are referring to the A/T of a honda crv. walang O/D button ang crv. ang katumbas ng O/D sa crv is D4. turning off the O/D in your rav4 is like putting the shifter of the crv to D3.Signature
November 10th, 2005 10:31 PM #33
that's a misconception, the higher the gear = higher speed, the more fuel efficient, OD allows the choice of an extra-high overall gear ratio for high speed cruising, thus saving fuel.
November 10th, 2005 10:41 PM #34
btw...ive seen some posts that looks like some guy is getting behind the wheel for the 1st time and thinks that an A/T car would be like "taking a walk in the park"...my best advice would be to enroll in any driving school for a few days or ask an "experienced" driver to teach you....one of the worst driver on the road is a guy who is trying to learn to drive by himself!
Don't rush...it's better to know the basics and driving would be a lot more fun & safe not only for you but for others as well....
November 10th, 2005 10:49 PM #35
OD is like your 5th gear on a manual tranny, mas matipid sa gas since less engine revolutions per turn of the wheel. so when you have the OD off all the time it is like driving a manual tranny car using only 1st-2nd-3rd-4th gears. bakit ayaw mo gamitin yung 5th sa manual?
also in some a/t (conventional a/t, NOT cvt) OD ON locks up the engine crankshaft with the sun gear input shaft (hope i do not have to say that we assume it has already up-shifted pass D1-D2!), in effect by-passing the torque converter. the a/t tranny then works just like a manual tranny in 4th and 5th gears, no more hydraulic losses from the torque converter. (please don't get confused, an a/t tranny has 2 parts - the hydraulic torque converter and the planetary gears).
besides, why worry about this? that's what the ecu is for. just keep it in OD and let the ecu do the math, unless of course if you can compute optimum efficiency faster than a silicon chip can.Last edited by yebo; November 10th, 2005 at 10:53 PM.
November 10th, 2005 11:10 PM #36Originally Posted by marlon22701
November 10th, 2005 11:21 PM #37
Thank God nothing serious happened....that was really a close call....thanks for sharing that with us, i do hope the message goes thru to the others as well.
November 10th, 2005 11:29 PM #38
lagay mo na lang kasi sa D! why do you need to play with the shifter eh automatic nga yan. the only time you need to shift manually on an a/t car is when engine braking on a downhill road. if you need to downshift when overtaking just floor the gas pedal and it will downshift automatically.
November 10th, 2005 11:58 PM #39
now if its a steep uphill, that's a different story, then you'll need to downshift to 3 for A/T if you feel the engine lacks power....
November 11th, 2005 12:28 AM #40Originally Posted by marlon22701
Traffic!
