Results 11 to 16 of 16
- Aug 2005
- 87
January 18th, 2006 09:17 AM #11gud day guys, napa drain and pinalitan ko na bago atf ung civic ko but still the same. basta bagong start or cold start, maganda takbo laging nagshi-shift ung gear pero once uminit na yung makina then huminto ka ng matagal something like na-trafic ka for 5mins or nagpa-gas ka lang, patayin or hindi mo man ung makina, once na umandar ka ulit di na naman magshi-shift ung gear. laging ganito daily. tinignan na ng friend ko lahat ng wirings papunta sa computer box pero ok naman daw lahat.
do you think there's something wrong na with the transmission? suggest nya convert na lang daw namin sa M/T dahil mas less ang gastos kesa paayos ung A/T nya.
Tsikot Member Rank 5
- Nov 2003
- 3,849
January 18th, 2006 10:12 AM #12if you go manual you have to replace a couple of things including your computerbox, iacv, pedals, shifter linkage, flywheel, clutch disc, pressure plate and release bearing, clutch primary, plus the tranny itself. a couple more things also that i'm probably leaving out.
- Jan 2006
- 3
January 18th, 2006 11:22 PM #13my car is also Honda VTEC 96'. same problem with mikejohnny how could you tell that the A/T is already broken or need to be replaced.
OT: and if someone know's the TEL# of SpeedyFix or Baltak Motors please let me know thank you!!!
Sowee im just new here.
January 19th, 2006 10:37 AM #14
Troubleshooting AT is extremely difficult, but in most cases yung torque converter ang may problema or yung TCM...
Geoffrey: Please do a search for the location, number and direction for the 2 shops mentioned.
January 19th, 2006 10:59 AM #15
try
1. replacing the auto transmission fluid
2. resetting the computer (by disconnecting the negative battery terminal for about 5 minutes)
3. also to install a grounding kit from negative terminal to the transmission body (wild suggestion lang)
there's an A/T specialist near tesda in the east service road of bicutan (near fort bonifacio gate 3
- Nov 2003
- 3,849
January 22nd, 2006 09:53 PM #16just get a surplus one... might be easier and better than rebuilding the engine.
Daming issue ng SU7:grin:
Xiaomi E-Car
