Results 41 to 44 of 44
June 25th, 2019 06:19 AM #41
- May 2011
- 481
June 26th, 2019 06:59 AM #42If I'm not mistaken, this transmission was made by aisin warner. When the O/D or D shifter indicator flashes, it usually means IPSO ( input, process, storage, output) problems. First check the basics: fluid type, level and condition. Then check the enable criteria sensors: coolant temperature sensor, transmission fluid temperature sensor, vehicle speed sensor, throttle position sensor. If you can, have the PCM and the transmission control module(if applicable) scanned for trouble codes and read the PIDS comparing normal ranges and actual readings. Do not guess and second guess. Everybody can be a fortune teller or a Feng Shui expert.
June 26th, 2019 02:33 PM #43
- Jun 2020
- 1
November 28th, 2020 02:26 PM #44Hi. I have the same problem with my 2013 Strada GLS V. I know this is not normal because whenever i go up marcos highway or kennon road it will get stuck at 2nd gear. Every damn time it really annoying actually.
Sent from my POCO F1 using Tsikot Forums mobile app
puede hahahah tapos 6 speed manual na rin :grin: The ultimate sleeper MPV, Innova GR.
The Ultimate Yaris
