Results 11 to 20 of 28
    Quote Originally Posted by Dianne
    Sorry ha di ko pa to nagawa eh... how do you adjust ba the clutch cable?... may parang adjustment ba yan na clockwise or counterclockwise? advisable ba na maglagay ng lubricant sa clutch cable?
    Yup, sa clutch pedal. Depends kung mataas (tukod) or mababa ang clutch. I put lubricant sa cable every now and then. It helps smoothens the feel...hmmm
    Kung hydraulic assisted ang clutch mo baka kailanagn mo na palitan yung fluid. After a while nagtutubig ang clutch fluid just like brake fluid eh.
    Mine is Adventure... so san ko siya lalagyan ng lubrication at paano? I've seen the cable from inside the car, its going upwards. Hindi ko masyado nacheck pero di ko pa nakita sa engine bay. puwede ko ba siyang lagyan without removing the cable?...
    pwede i adjust sa clutch pedal lang? masahdo mataas clutch ko e. wala bang maaapektuhan if DIY lang adjustment? :?:
    Dianne::: is your adventure gas or diesel?
    CoolGal:::Puwedeeee. it's either you adjust it , lalon tumaas or bumaba (hindi mo na shift)
    pano adjust? alin? yung sa clutch pedal o yung sa cable? iniikot lang?
    Quote Originally Posted by afrasay
    Afrasay,
    Gas... Super Sports... Di ko pa rin alam kung pano lagyan ng lubrication sa cable nor sa spring?... di ko makita kung san puwede...
    miss dianne
    my dad also has an adventure...gls model...2002 model...
    yeah...medyo matigas nga ung clutch ng adventure....di ata kasi hydraulic ung clutch nito....
    sakin din ganito... :roll: 96 galant ss po
    ganito din kaya remedyo or baka ubos na clutch fluid ko? :cry:
    Defintely mas matigas ang clutch cable kaysa sa hydraulic type type (parang joke ito ha...). It a matter of observing the pedal pressure kung bumibigat kaysa sa dati.
matigas clutch pedal
