Results 1 to 10 of 28
November 13th, 2002 12:39 PM #1
Peeps,
How can i make the clutch of my Lancer Gli a little softer, matigas kc, you need a lot of force to step on it esp. when you're shifting to reverse gear? :?
- 37
November 13th, 2002 01:06 PM #3
Colt45,
yan bang clutch mo e di kable? Kung di kable yan, maybe it's time for you to replace/adjust the clutch cable
November 13th, 2002 01:06 PM #4
baka nga yung return spring. pa check mo din clutch system mo, parang dati yung frend ko meron ding ganyang problema sa nissan sunny p-up naman nagpalit ata sya ng pressure plate (im not sure sa parts).
- 59
November 13th, 2002 02:33 PM #5hmmm lancer glxi din auto ko bosing... ako nung una gusto ko na din papalit may nag sabi sa akin compared to other car brand mejo matigas talaga clutch natin mkhang totoo naman kasi lahat ng kilala ko na may lancer itlog ni test ko clutch o kaya nman tinanong ko may katigasan nga compared sa ibang car make... sana may iba pang mag comment about this
November 13th, 2002 02:59 PM #6
kung cable type yung clutch mo try to lube it using motor oil or any oil based lubricant,
- Nov 2002
- 82
November 19th, 2002 06:13 AM #7medyo matigas din clutch ko compared to toyota dahil cable yata ang atin di tulad ng toyota and other cars na fluid ang gamit mine is mitsu gli may baon ba kayung clutch cable dali daw kasi maputol e sabi ng mekaniko ko
November 19th, 2002 08:48 AM #8
two things first before you consider a full repair..
a) kung cable type yung clutch, i suggest bugahan mo ng wd40 yung loob ng cable (that is after disconnecting it..). baka puro dumi na yung loob;
b) try adjusting the clutch cable tension (diy) lang.
if these two things do not work, try changing the cable and have it checked na rin. mahirap maputulan ng cable while on the road.
November 19th, 2002 10:18 AM #9
thanks for all of your reply guys. i guess we just have to live with it. anyway, generally ay satisfied naman ako sa itlog ko, este sa lancer ko.:wink:
- 109
November 23rd, 2002 07:59 AM #10Sorry ha di ko pa to nagawa eh... how do you adjust ba the clutch cable?... may parang adjustment ba yan na clockwise or counterclockwise? advisable ba na maglagay ng lubricant sa clutch cable?
