Page 1 of 4 1234 LastLast
Results 1 to 10 of 35
    Oct 2008
    Hi mga tsikoter's. Very Nice na meron po ganitong Very Informative Forum Site about tsikots, napaka helpful sa tulad kong newbie sa auto lalo na sa mga students. Medyo Newbie po kasi ako sa pag dridrive, bahay-school lang ako parati. Ask ko lang po if masama po ba lagi nakababad sa clutch?? Ano po kaya possible masira kung lagi nakakabad sa clutch lalo na sa hangging??
    Jan 2008
    yes, IMHO, if you are a clutch baby, one sure thing na masisira dyan ay yung clutch disc assembly at ang clutch master nya.So if you are a clutch baby, lagi na lang alanganin yung engagement ng transmission at clutch disc kaya yung disc surface is subjected to stress. Ditto with clutch master, lagi na lang me pressure dun sa rubber seal nya kaya madaling bibigay yun ergo kapag bumigay ang rubber seal tatagas yung brake fluid na ginagamit bilang hydraulic fluid nya. The result? Failure of the manual transmission gears to synchronized with the flywheel and clutch disc assembly.
    Oct 2008
    Sir, thanks for your input. But, how will I know if sira na Clutch ko?? Anu po magiging symptoms kung malapi na masira yung clutch ko??
    Feb 2006
    sa experience ko, my car had vibrations when releasing the clutch from full stop. tas yung isang friend ko, di nya ma-shift at all even with the clutch applied
    Oct 2008
    I will be better if you can avoid stepping on the clutch when not necessary.
    It will be hard to shift when there is a problem with your clutch because it will not fully disengage or engage the transmission from the engine. You might also experience the vibration like recklus said because the clutch have been burned or melted with the flywheel thus problem with disengaging even at full stop.
    May 2007
    Quote Originally Posted by joseph20 View Post
    You could ruin your clutch easily and surely, mechanic shop will love you. Bad for you, but not for theme.
    Oct 2008
    masama talaga magbabad ng clutch kasi ang masisira dyan ang release bearing, pressureplate clutch disc at pwede na din yung flywheel.. kasi ang clutch system natin parang sandwich yan.. tapos seesaw method...
    Oct 2008
    Quote Originally Posted by recklus View Post
    sir try muna pa adjust yung clutch freeplay.. or baka sira na yung spring ng pressure plate... tnx
    Oct 2008
    Para alam ko po yung cost kung sakali palitin na, how much po kaya yung pressure plate at clutch disc?? Wala pa naman po ako nararamdam na symptoms na vibration or hirap mag shift, medyo matigas lang i press kaya medyo nakakangawit. But, anyway, thanks for all the info, very informative po lahat.
    Sep 2006
    Kung wala ka pang nararamdaman wag mo nang problemahin. Better concentrate on removing that bad habit of being a clutch driver. Most of the time nasa owner's manual nakalagay, NEVER rest your foot on the clutch pedal. Even a slight push engages the clutch resulting in premature clutch wear over time. Kaya merong false pedal sa left side ng clutch para doon mo ipahinga left foot mo when not in use.
masama po ba babad sa clutch?
