Results 21 to 29 of 29
BANNED BANNED BANNED
- Sep 2015
- 13,919
October 11th, 2015 12:44 AM #21Nag research ulit ako online and from 99% eh 99.8% na ako ito problem ko.
CV joints - Car Talk
A bit of a flare for the dramatic there. I'll tell you what, mjkelley - if you have a sudden CV joint failure that sends your car end over end on the highway, and if you live through it then buy a lottery ticket as soon as you can b/c you're apparently on the thin side of the odds that day.
I'm not saying squirrely things can't happen b/c they can, especially at high speed. But basically if the joint completely fails it cuts transfer of power from the engine/transmission to the wheels. So the most common thing that happens is that the car just won't go. If you are driving it you will find that you can't accelerate & will come to a stop. If you're stopped you'll remain so. The squirrely things can happen b/c there are multiple axles w/ 2 joints each.
CVJ's click bad and quit altogether when they are past bad. You get 0 power to the driving wheel. The inner joint spins in the outter joint then. You just hear rattliing and get no go.
Read more: Can defective CV joints cause drag and sluggishness? (idle, brakes, tires) - Automotive -Sports cars, sedans, coupes, SUVs, trucks, motorcycles, tickets, dealers, repairs, gasoline, drivers... - City-Data Forum
- 52,516
October 11th, 2015 08:18 AM #22i'm waiting for developments when TS finally opens up the suspects...
curiouser and curiouser..
- 52,516
October 11th, 2015 08:18 AM #23i'm waiting for developments when TS finally opens up the suspects...
- Jun 2005
- 3,762
October 11th, 2015 10:07 AM #24kung 99.98% sure, go for it. let us know kung eto nga talaga. wag mo isabay pagawa yung iba para ma-eliminate mo. snap us a photo of the cv joint too.
October 16th, 2015 03:34 PM #25
- Sep 2015
- 13,919
March 31st, 2016 01:17 PM #26-
Update sa problem ng kotse ko. Hindi sliding ang clutch. Ang culprit yung cv joint/driveshaft. Mali ang pagkabit nung year 2005 parang nabaklas yung lock according sa mechanico. Ngayon napalitan na.
Grabe kung nakinig ako doon sa first three talyer na sliding na daw eh hindi rin maayos. Buti na lang limang talyer pinuntahan ko.
April 9th, 2016 03:54 PM #27
Can Changing your Transmission Fluid Cause Damage? - YouTube
Found this on youtube, very informative. RE: Transmission fluids.
- Aug 2015
- 220
April 19th, 2016 09:09 PM #28Exactly same din ang symptoms na nangyare sa car ni esmi, nagkaroon din ng tok tok sound na nawawala rin naman, then suddenly one time galing sa pagsundo kay bunso biglang hindi na makatakbo kahit anong apak ng gas.
Velocity joint naman ang tawag ng mekaniko, nabaklas na raw ang bearing assy kaya hindi maitransfer ang engine power sa gulong.
It cost us php1500 para sa velocity joint assy + php500 sa labor. By the way, her car is Nissan.
sent from my Nokia 3210i
- Sep 2015
- 13,919
April 20th, 2016 02:40 AM #29Oh di ba. Limang talyer pinuntahan ko, first four sabi palit na agad clutch disk, sliding na daw. Pero yung last na talyer sinasabi ko pa lang symptoms alam na agad problem. Dinemo sa akin bakit yun ang nangyayari.
Mahirap kasi pag nakasanayan sunod na lang agad. Eh buti na lang segurista ako at inalam ko talaga symptoms kung totoong sliding na clutch ko eh hindi naman.
as an aside, in the olden days, anyone who does not move 'ala luksa during Holy Week, especially...
Traffic!
