Results 1 to 5 of 5
March 25th, 2014 09:11 AM #1
hello po!
mga ser, bakit itong diesel ride ko pag naka idle makina ng matagal. nagiislide yung clutch?
frequently happens when the weather is hot. but after some kilometers drive (a/c off), slipping siezes.
can somebody diagnose this please? my ride served 178k++ of joy.
salamat sa sasagot!
April 7th, 2014 11:59 PM #2
Hindi ko ma-gets. Paki-elaborate ng maige, or give a specific scenario..idle? (meaning naka-menor), sliding clutch...alam ko sliding clutch e once na pagtapak mo sa gas at bira ka ng bira walang binibigay na arangkada or hatak..yung tipong ugong na ang makina pero wala pa rin takbo/mabagal ang takbo.
April 8th, 2014 11:11 AM #3
April 8th, 2014 03:04 PM #4
I try mo muna magpalit ng gear oil at baka contaminated na yan kasi matagal na dapat for renewal or mali ang grade ng gear oil na nagamit
If ever hindi sya magbago sa palit gear oil lang, then tsaka mo na ipa check kung may problem on the following
1) Clutch lining baka malipis na
2) Clutch disc na contaminated ng grease lang
3) Pressure plate
4) Diaphragm spring
April 13th, 2014 01:45 PM #5
idle chong, pag naka on yung makina ng matagal at tinambay ko lang. kunwari ihininto ko muna (pero naka sindi) kasi bigla kong naisipang bumili ng modess sanitary napkin (without wings) sa tabing tindahan. tapos pag inarangkada ko, humihiyaw na yung makina tapos walang o ang tagal ng hatak chong.
hindi ko naobserbahan ser. pero may sumpong siya na pag naka idle ng 20 minutes or so at lalo na tirik yung araw, parang gusto ko ng tumalon ng oto ko at pumara ng taxi.
thank you ser! ipagagawa ko lahat yan! actually clutch ko medyo 3 years pa lang. hindi ako clutch driver (sa tingin ko). may hinala ako nalalangisan yung clutch disc ko gawa ng pagbulwak ng motor oil sa dip stick ko. pag sinilip ko ilalim ng makina, basa ng langis.
thank you ulit!
you're the man!
One dude told me it was Li-Ion. Another dude corrected him. AFAIK the Zenix gets the Li-Ion hence...
MG4 EV Standard vs BYD Atto 3 Dynamic vs Toyota...
