Results 1 to 5 of 5
- Jan 2010
- 52
January 17th, 2010 09:01 AM #1Hi Everyone,
I'm new here to tsikot and was wondering if anyone could recommend a good shop in Manila where I could get my car fixed. My car is 1998 Honda EK3. I am not 100% sure that it is a transmission problem but am thinking it is because of the following:
a.) RPM reaches high levels even at a slow speed (pakiramdam na parang di sha nagsshift ng gear - feeling na pag nakamanual parang todo apac sa gas without changing gears.
b.) pag palit ng gears, parang biglang nawawalan ng bisa ang gas pedal.
btw - Di ako talaga from Manila, only working here kaya any suggestions of good shops are welcome. Also, kung talagang sa Casa lang talaga tingin nyo pinakamaganda, let me know
Thanks,
RPP
January 17th, 2010 10:20 AM #2
Bago mo pa check iyong transmission mo check mo muna ATF fluid mo baka marumi na dahilan din iyan sa problema mo . Gusto mo mag inquire ka muna sa Street Spec sa Banawe QC . Malapit sa orthopedic hospital.
January 17th, 2010 10:44 AM #3
Good day sir!
wala ako mairrecommend na shop sa 'yo pero sure ako na transmission problem yan. Ganyan din ang nangyari sa dating car ko nung di naikabit ung clamp sa transmission fluid hose nya. natapon halos lahat ng ATF. RPM reaches high levels without moving forward. Paki chek sir ng ATF fluid level mo, baka konte nalang.
Good luck po.
- Jan 2010
- 52
January 19th, 2010 03:04 PM #4
