Results 31 to 34 of 34
- Nov 2009
- 87
January 2nd, 2010 09:13 PM #31"sa umaga one click lang, pero once mainit na makina o after a trip pag pinatay ko makina then start again ayaw na.not even a single crank".
If this is the case my suspect is your battery. It might be weak already. Eh why sa umaga it STart? PLEASE BE INFORMED that the whole night your battery have recovered it's strength. Kapag hindi umistart po, please check your battery voltage, it should have a reading of 12.5vdc or a little bit higher sa multi meter tester. Now start your engine or crank your engine with the tester in place sa battery terminals, it should have a reading of 9 vdc and up habang ineestart. If the reading is 9, 10 ,11vdc your battery is GOOD! .if below 9vdc, say 8, 7, 6vdc. replace your battery or Check first your alternator and voltage regulator, your charging system might giving you a problem.
January 3rd, 2010 05:45 AM #32
commom symptom of a car 5 years or older. usually, this is caused by dried up grease the factory installed inside the PRND2L switch that sticks, but allowed to rest and cool down, the springs that pushes the little copper sliding contact bar inside the PRND2L makes contact again. just to cover more possibilities since it is giving symptoms already, check the starter relay too. another temperature related cause would be worn brushes that the spring is trying to push to make contact with the armature commutator bars.
jick
- Oct 2010
- 1
October 20th, 2010 07:41 AM #33ang problema ko ay hard starting. kapag malamig pa at sa umaga ok nag iistart agad pero pag mainit na ayaw ng tumuloy ang start redondo lang hanggang 3x bago nag tuloy ang start.. at minsan na di diskarga ang battery..a/t transmission ito na hiace super custom from subic..pls...help me din.
Yes Yes squeaking sound is heard when shifting only
