Results 1 to 8 of 8
Tsikot Member Rank 4
- 1,842
October 9th, 2006 03:44 PM #1After akong lumusong sa baha nagkaroon ng grinding sound. or hissing sound (Mahinang sound) Ano kaya dapat? imediate replacemnet ba ng clutch assembly? or kaya pa itagal
- 1,842
October 10th, 2006 10:50 AM #3
sir, baka release bearing lang yan.do you only hear the sound when you step on the clutch pedal?
October 10th, 2006 01:25 PM #4
maybe your beer is rubbing against your cupholders :D
Seriously, kailan ka na baha? yun mga kakaibang sounds after mo mabaha usually goes away after a day or two pag natuyo yun mga parts.
- 1,842
October 10th, 2006 02:58 PM #5noong milenyo
pinacheck ko nga sa mekaniko ko ang sabi nya release bearing daw at palitan na nang whole clutch assembly
yes pag nakatapak lang ako may hissing sound.
Nagkaroon din nga pala ng parang gap sa clutch parang malaking slack pero nawala na din.
Salamat mga tsong antay ko muna results after some days sana mawala.
Its not the beer can too. Its probabaly the milk carton hehehehe
October 10th, 2006 04:46 PM #6
sir max,
sounds like the release bearing needs to be replaced. usually di na mawawala yan. next sisirain nya is the pressure plate (clutch cover)...
October 10th, 2006 04:47 PM #7
Observe a bit muna... if it does need to be changed (most likely culprit is the release bearing) and medyo matagal na yung cluthc mo then change the whole assembly na rin kung kaya ng budget para sulit ang labor.
October 11th, 2006 03:25 AM #8
probably the release bearing or a combination of both the release bearing and the pressure plate. anyway kahit na one of those lang ang problema, it's advisable you replace both of them, plus the clutch disk para isang babaan lang ng transmission (medyo mahal labor). and get orig/OEM parts instead of replacement parts.
One feature they should incorporate in EVs is speed limiting based on the keyfob you hand over to...
