Results 31 to 39 of 39
- Nov 2010
- 15
August 31st, 2021 09:50 PM #31I plan to do just that pag makauwi na ng Baguio. [emoji106]
Sent from my Pixel 4 XL using Tapatalk
September 1st, 2021 04:02 PM #32
September 1st, 2021 04:49 PM #33
Aim & key here are to extract the most of the old fluid out & get the correct amount of new in. Note that volume or level check must be done at factory-recommended fluid temperature range(varies w/ make & model).
What bothers the OCD in me w/ 'dialysis' equipments is the high likelihood of having some other type of fluid mixing w/ your new CVTF. This I won't do unless I'm sure the equipment is totally clean. CVTF & ATF SHOULD NOT MIX.
You can drain/fill multiple times w/ some driving in between. This method dilutes the old fluid w/ new. The more times the better.
The cooler/heat exchange line method, as done in the video, would be more ideal. More old out & new in w/ lesser contamination/dilution. To add, I'd probably drop the pan & change the filter/strainer every 2nd or 3rd fluid change intervals...for units applicable. Some trannies are sealed type.
Subaru CVT Transmission Fluid Change & Flush Procedure | 2015 Forester Replacement-Fill-Level Check - YouTube
Tedious, yes...but peace of mind of having something done right is priceless.[emoji4]
September 1st, 2021 05:23 PM #34
i'd only do the tranny fluid flush if I was sure the previous owner did regular fluid changes religiously. If in doubt I'd do a drain and fill with the pan dropped just to see how the fluid looks. If it's clean and not much dirt in the pan I'd do the flush next time. The passages in the valve body of these things are so tiny that flushing super old fluid which may have solidified particles in it might result in a blockage.
September 1st, 2021 06:28 PM #35
CVTs are best enjoyed new. If planned for longterm keeping, care & regular flushes are needed more than traditional ATs....If not, wish the next owner luck.[emoji849] When(not IF) CVT troubles pop, chances are high for tranny replacement.
September 1st, 2021 07:12 PM #36
September 1st, 2021 09:46 PM #37
Electrics are an easier proposition than the current messy platforms of complex modern electronics running, nannying & choking the ancient combustion engine. Efficiency at the expense of reliability. Then you have regulations dictating to clean the fossil fuels we burn? Hybrids, CVTs, DPFs....Messy, messy, messy.[emoji13]
- Jul 2009
- 2,618
November 15th, 2021 12:55 PM #38
November 15th, 2021 07:36 PM #39
Hmmm.... Kailangan na ng aircon service niyan innova mo. I have a blackish red innova. Bilad sa...
