Results 11 to 17 of 17
- Aug 2014
- 26
February 13th, 2015 11:54 AM #11kakalinis lang ng filter sir wala naman metal shavings and fluid is good. Yup mukha nga solenoid pero it should throw a code kung solenoid ang problema since yun din ang nabasa ko sa Service Manual, baka pwede rin sa Valve Body.
Failure to change gear from
“D1” to “D2”.
1. PNP switch adjustment AT-272
2. Control cable adjustment AT-272
3. Shift solenoid valve A AT-178
4. Control valve assembly AT-303
5. Vehicle speed sensor·A/T
(Revolution sensor) and vehicle
speed sensor·MTR
AT-121, AT-205
“D1” to “D2”.
speed sensor·MTR
AT-121, AT-205
- Jul 2014
- 162
- Aug 2014
- 26
February 16th, 2015 08:42 AM #13
- Mar 2015
- 10
July 21st, 2015 09:17 PM #14Bumping an old thread. Any idea sir on how much is the solenoid assembly for 96 galant super saloon 4 cylinder? Intermittent upshift din kasi sa akin. Normally, pag 'normal' temp na, high rpm but speed reading is low and slowly catching up. Nalilinis din ba ang solenoids sa tranny? Or palitan na lang instead of doing some pansamantagal tactics? Btw, already change atf 2 weeks ago. Yung filter ang di ko pa nachecheck. Pwede din ba atf filter mag cause ng intermittent upshift pag barado?
- Jul 2014
- 162
July 23rd, 2015 05:30 AM #15Wala ako idea sa switch ng F4A22 kung magkano ang set. Pero sir okay ba ang atf ng pinalitan nyo? Hindi sunog at walang mga metal debris sa atf? Try mo pa check sir ang valve body kasama na ang EPC at TCC sol. Pati na rin ang kick down pa check mo ang adjustment.
- Aug 2014
- 26
July 31st, 2015 10:27 AM #16Update ko lang, Speed Sensor sa Transmission ang naging problema (1.2k surplus), napalitan na since March and no problem since. Lumabas yung error code sa scanner kaya napinpoint agad and hindi na binaba yung tranny. Kaya better to have it scanned first and check the service manual.
- Nov 2015
- 5
November 15th, 2015 05:29 PM #17Hi. Need advice. Ung transmission ko kase may problem sa reverse. Delay ung response ng reverse shift tapos nung pinacheck ko ang problema daw is wiring dun sa inhibitor na nagcoconnect sa transmission ko. True po kya un? Ska magkano ba pagawa ng wiring?
normally, i would feel for the e-bike and e-trike users, as "these are probably all they can...
E-bike / E-trike ban details released by MMDA
