Quote Originally Posted by tip_tipid View Post
is the car rolling and at what speed when you "manually" shift?
is the car rolling and at what speed or rpm when you "manually" shift?
It does rolling and i manually shift between 2000 to 4000 rpm but it does not upshift when downshifted from 2 to 1 then manually upshifted.
When the stick shifted to full auto (D), the car seems like normal to drive. Problema lang talaga sa sports mode (or whatever enthusiasts call this mode with (+) and (-) sign on cvt engine).
simula lang talaga nung nawala ang gear indicator na yan sa tabi ng D, hindi ko na magamit ang upshift sa sports mode.
