Results 1 to 5 of 5
November 12th, 2012 10:20 PM #1
noob lang po sa AT which one should i use going downhill? to be specific un downhill ng Subic area, kaya ba i-shift un AT from D to D2 while moving or should i stop muna before shifting sa D2? or i just click the OD off mula sa entry ng Subic-Tipo? tnx po sa mga mag advice
November 12th, 2012 11:21 PM #2
No need to stop if you're shifting from D to D2.
As for what shift program to use - it will depend entirely on you. D2 will give you stronger engine braking, but I think it's overkill for the Tipo highway if you aren't driving aggressively. D without overdrive should be fine unless you absolutely need the engine braking because you're about to crash into someone else's rear bumper.
November 12th, 2012 11:52 PM #3
For me, D lang ako... Hindi naman steep downhill iyan...
If you want, then you can just turn off your overdrive (by pressing the button), or go to D2,- no need to stop to do any of these... Just be sure that you are not running too fast,,, 60KPH should still be okay, I think. Consult your manual just to be sure....
17.3K:type:
November 13th, 2012 02:09 AM #5
I have been in Subic twice...also an AT driver. I just used D all the way from Subic to Manila. And for sometime running * 130-140
Discover the ultimate in relaxed romance with the best casual dating platform! Authentic Ladies ...
Exemplary Сasual Dating - Verified Damsels
