Results 1 to 3 of 3
October 9th, 2011 10:08 PM #1
good day mga paps..question lang, where makikita or check ang transmission fluid or gear oil..corolla gli 99 m/t..thank you tnx..
October 11th, 2011 10:08 PM #2
your transmission is equipped with two plugs for servicing gear oil, one on the lowest part is the drain plug, the other on the same level as the driveshaft is the filler plug. the fluid is properly serviced if you can reach the fluid level to the first joint of your finger or up to the same level as that of the filler plug hole
3M Color Stable series are all above 50% TSER. RFID readable through the tint, stays good for...
What's the best car tint brand and color?
