Results 21 to 30 of 79
October 14th, 2005 09:49 PM #21
my L200 before had 280k kms registered and the clutch assembly was replaced only once. mostly highway kc ang gamit (through out mindanao) no traffic.
Tsikot Member Rank 5
- Nov 2003
- 3,849
October 16th, 2005 12:18 PM #22you can make a stock clutch last till 100k or more depending on driving style. on the other hand, i have some customers that replace the clutch twice a year because they use upgraded race clutches and like to do burnouts. hehehe!
October 16th, 2005 12:36 PM #23Originally Posted by speedyfix
- Nov 2003
- 3,849
October 18th, 2005 09:55 AM #24higher torque capacity yung pressure plate and higher coefficient of friction yung clutch disc material for better bite and more resistance to heat.
December 30th, 2010 11:04 PM #26
bumping this thread...
migs - any suggested race clutch or clutch for a nissan s3? autocross mostly laro. Plus a ballpark figure would be great and where to buy.
By the way. Lumipat na kayo?
- Nov 2003
- 3,849
December 31st, 2010 08:53 AM #27it really depends on the engine. if it's the stock one i might not have an upgrade for you. normally the upgraded clutches are available for the more performance oriented engines to begin with. exedy race clutches will start in the 14-16k range for the disc and pressure plate and move up in price depending on application and type of clutch.
December 31st, 2010 11:34 AM #28
thanks migs! Might look for exedy clutches and maybe a more semi performance oriented pressure plate.
- Nov 2003
- 3,849
December 31st, 2010 10:09 PM #29good luck looking! depends also on the power output of the engine. normal bolt ons will still be ok with the stock clutch. you only really need to upgrade when you're making around 30% and up more power than stock
- Feb 2015
- 1
February 1st, 2015 01:34 PM #30Speedyfix
maganda din ba yun AISIN brand clutch assembly para sa toyota corolla 95 model? o anu mas recommended mong brand. For normal driving lang.
