Results 1 to 10 of 79
Tsikot Member Rank 4
- 1,842
September 23rd, 2005 08:29 PM #1Questions on clutch servicing maintenance
1. Any sign or symptoms on when to replace clutch?
2. What basic parts do I need to replace? How much?
3. To maximize cost put in labor, any other thing to replace or checked?
4. Recommend alternative brand for parts. (Besides Manufacturers Brand)
5. Recommend a shop
September 23rd, 2005 10:06 PM #2Originally Posted by MAXBUWAYA
2. clutch disc, bearings, pressure plate and alignment tool
3.
4. clutchmasters (they have oem replacement & upgrades)
5.Last edited by ghosthunter; September 23rd, 2005 at 10:28 PM.
September 23rd, 2005 10:21 PM #3
here is a funny thing that i never research even if i managed a lot of different casas out there from korean, japanese, and european vehicles.
we always replace everything clutch disk release bearing and pressure plate.
this way no hassle for us to just replace 1 part and if there is a back job we wont need to replace the others.
so if a customer comes with sliding clutch and our technicians sentence it as replace clutch disk due to wear. everything is replaced.
we do it so that we wont have a back job and have to remove the transmission again.
Do others out there just replace the worn part? Just the clutch disk and not the whole clutch assy?
September 23rd, 2005 10:22 PM #4
Sliding into 5th gear, premature wear, sign that may need replacing within a week. Sliding on 4th or 3rd gear, buys those parts and hope it won't damage the flywheel. For manual trannys, while the engine is running at stand still (not the vehicle), engage in top most gear (4th or 5th), slowly release clutch pedal, if engine did not stall, time to replace.
Clutch disc, release bearing, pilot bearing/sleeve, pressure plate. Prices differ for each make & model.
Flywheel damage from rivets, oil seal, transmission links if equipped, park brake lining and tension if equipped with parkbrake after tranny assembly.Last edited by Ungas; September 23rd, 2005 at 10:24 PM.
September 23rd, 2005 10:23 PM #5
1. May shudder when coming from a dead stop. You can put it in fifth gear while stopped, release the clutch and engine won't die.
2. Clutch disc. Good idea to get a new pressure plate, release bearing while you're at it.
3. See above
4. Centerforce, then there's this other Japanese company I can't recall right now. Personally, you can't go wrong with OEM.
5. Cousin Ferdie
September 24th, 2005 12:18 PM #6
4. Daiken/Exedy
btw a squeaking sound in the clutch pedal, plus, sometimes total loss of clutch pedal resistance (e.g. the clutch pedal drops to the floor, no resistance, and can't change gears anymore) what is this? happened to me 3 times now. Pretty annoying/unnerving. But the clutch pedal worked itself back up within a few minutes, and I went on with my driving..
September 24th, 2005 01:53 PM #7Originally Posted by orly_andico
ASCO is also okay when i tried it on our Corolla (but this was with a torqueless 1.3L engine)...
Tsikot Member Rank 5
- Nov 2003
- 3,849
September 25th, 2005 01:35 PM #8fcc, asco, daiken, etc are all ok naman.
replace everything pati oil seals so no need for work to be done again next time.
- Aug 2005
- 28
September 25th, 2005 02:33 PM #9Additional question: any cost estimates? I know it varies from car to car but does anybody know the range of cost?
- Nov 2003
- 3,849
September 28th, 2005 10:39 AM #10from 5-10k for everything depending on the car.
syempre, 4x4's are more expensive kasi parts are generally sturdier and labor will be more.
of course! the former was more enlightening than reading the Holy Book. mom loved the Ten...
Traffic!
