Results 31 to 40 of 46
Tsikot Member Rank 5
- Nov 2003
- 3,849
July 20th, 2008 11:32 AM #31most of the bigger auto supplies will have. lalo na if they specialize in higher quality parts. the clutch alignment tool mahihirapan ka to buy... mostly shops lang meron who either make their own or order it from abroad.
- Oct 2008
- 23
November 21st, 2008 08:27 PM #32Bakit po kung minsan nahihirapan ako magpasok sa first gear kung minsan naman madali. Sa first gear lang naman po. Kapapalit ko lang ng clutch. Sabi sakin baka sa timing lang ng pagtapak sa clutch at change ng gear kaya lang bakit dati di ko naman napapansin na mahirap at sa first gear lang nangyayari? tia po sa reply.
- Nov 2003
- 3,849
November 30th, 2008 04:11 PM #33try adjusting the free play of the pedal. it might work. maybe the gear oil too if di pa nagagawa.
- Apr 2009
- 543
April 14th, 2009 01:09 PM #34
April 19th, 2009 10:51 AM #35
- Apr 2009
- 543
April 20th, 2009 11:48 AM #36
April 20th, 2009 05:18 PM #37
seiken is a good replacement. i didn't know they have aluminum and steel types for their clutch assys.
- Jan 2009
- 48
June 28th, 2009 06:17 PM #39
ako oem pinalit ko...bought it from tQa but have it installed sa reffered mechanic ng tiyuhin kong tiyuper... imagine: more or less P20K worth of parts and labor sa casa tapus a week or more nila sstock ung altis ko dun?
buy na lang the orig oem ones then have it install sa most trusted shop or mechanic mu
good day good luck sa ride mo
- Jun 2009
- 21
July 17th, 2009 08:28 AM #40pre i recommend you buy EXEDY-DAIKIN performance clutch,its the same brand used sa casa.as always.dapat dun ka sa suki auto parts ka bumili.one set yun:pressure plate,clutch cover,release bearing.yung release bearing.you can buy the brands like KOYO or NSK.
Monk-owned R53
