Results 11 to 18 of 18
April 11th, 2008 03:45 AM #11
tol,
eto problema ko sa tranny ko 6 years kona tinitiis, pag malamig engine at naka neutral may maingay na bakal kumakaskas...pag after 15mins of driving at mainit na ang engine, nawawala
nagpalit nako ng clutch disc, pressure plate, release bearing, pilot or pivot bearing, clutch fork, AT BUONG TRANSMISSION at ganun padin
SAGARIN KO LANG ENGINE KO AT BUONG ENGINE AT TRANNY NA PAPALITAN KO, nag email nako sa mazda USA at bka daw sa transmission input shaft yung iba naman sabi sa flywheel kailangan pa machine shop ko
hindi pwedeng release bearing kasi naka dalawang palit nako nun
at NAKA 7 TIMES NAKO BABA NG TRANNY
kaya kung sino makaka ayos nito..PM nyo lang ako...MAY NAG AANTAY NA PERA PARA SA MAKAKA AYOS NITO
MADAMI NG MEKANIKO TUMINGIN AT NAGTANGKANG AYUSIN TO...
WALA...WALANG NAKA AYOS EWAN KO WHY GANITO TO
- Jan 2008
- 4,726
April 11th, 2008 01:07 PM #12layo mo kasi sir..i have a recommended shop here in las pinas ROGHER AUTOCARE.. expert talaga to mamang mekaniko na to.. magaling gumawa talaga you contact him at 8733509 look for mang rogher
April 11th, 2008 01:44 PM #13
makiki-tanong na rin.... pwede ba i-partner ang exedy pressure plate sa ordinary clutch disc (japan replacement - ex. asco)? TIA
Tsikot Member Rank 5
- Nov 2003
- 3,849
April 13th, 2008 04:20 AM #14yup it should be ok. yung mga exedy naman na lumalabas na white box are just direct oem replacement ones. if you want the performance exedy clutches they will come in pinkish boxes
April 25th, 2008 01:59 PM #15
sir speedy:
ask ko lang, bakit matigas ung clutch ng civic ko? nagtanong ako minsan sa isang kakilalang mekaniko, sabi nya, "baka modified, racing clutch cguro yan." posible ba ung sinabi nya? thanks.
April 25th, 2008 02:09 PM #16
- Nov 2003
- 3,849
April 29th, 2008 08:42 AM #17if matigas sya and hindi aftermarket yung pressure plate it can be caused by a defective pressure plate or a release bearing na pasira na. minsan din from a bad master or slave. or for those with cable actuated tranny's a cable that is baluktot na or kulang sa lubrication.
- Nov 2008
- 148
January 31st, 2009 08:39 PM #18I have a problem similar to this. Yung ingay nawawala kapag naka-press ang clutch. Ang sabi sa mga nabasa kong forum, input shaft bearing daw. So nung nag-leak yung oil ng tranny ko pinababa ko na buong tranny at pinaoverhaul. Ang masama nandoon pa rin yung ingay. Sayang yung ginastos ko. Ang suspect ko yung clutch disk. But after reading this thread, I doubt kung iyon nga...
Sir forcemajeure, na-solve mo na ba ito?
Latest mileage:
