Page 7 of 9 FirstFirst ... 3456789 LastLast
Results 61 to 70 of 82
    Oct 2007
    #61
    Quote Originally Posted by speedyfix View Post
    it's ok to use dex3 on the tranny... drain it well and if possible do consecitive drain/refills to get all the dirty atf out.
    You mean I can use RP ATF on my 96 honda accord no problem? Have you actually tried it on this car? The manual says dexron II & RP ATF is dexron III. Just want to be sure. Thanks.
    Jun 2006
    #62
    dex 3 is backwards compatible with dex 2. its safe to use on your car.
    Mar 2003
    #63
    sir speedy, does a revo 1.8 AT have a reusable AT fiilter (screen type) or disposable type siya?
    Nov 2003
    #64
    thehitman777, on some cars the tranny does not have an oil pan to drop the filter. no need to change the plug either.
    17M, yes it's backward compatible. it also meets honda requirements for even the new transmissions.
    promdiboy, hmmm... i'm not positive... easier for us if you bring it over so we can check it out
    Oct 2007
    #65
    thanks userfriendly & speedyfix for the enlightenment.
    Nov 2003
    #66
    no problem!
    #67
    Sir, have a 96 Accord as well. so any brand of ATF other than Honda ATF-Z1 is fine right? Having costly ATF changes since.
    Thank you.
    Thank you.
    Mar 2005
    #68
    Always use Honda fluid for honda cars. Ok lang engine oil and coolant brake fluid. for transmission and power steering use Honda exclusively to avoid expensive repairs.
    Happened to me
    #69
    Ah ok. May mga nakita ako lately na nagcoconform sa ATF-Z1 standard. Mga pahabol na siguro to since ATF -DW1 na pumalit para sa mga bago.
    Thank you.
    Thank you.
    #70
    Quote Originally Posted by jasonub View Post
    Happened to me
    yes, it happened to my FD before. I used a non-honda fluid on the power steering. It leaked. Honda told me it was the cause (i forgot now exactly why but it had something to do to with the chemical components of the fluid i used) and they quoted me an astronomical amount for replacing the hoses and other parts.
Best ATF for high mileage automatic transmission?
