Page 6 of 9 FirstFirst ... 23456789 LastLast
Results 51 to 60 of 82
    Nov 2003
    #51
    depends if you wanna transtech it or just drain and replace.
    with a simple drain/replace you will use about 4 qts of atf. with transtech you can use between 10-12 qts. so price will vary.
    you can text me for the exact price
    Oct 2007
    #52
    Quote Originally Posted by speedyfix View Post
    Is a transtech necessary or pwede na ang drain & replace? probably by next ATF change fully flushed out na ang mineral ATF na natira, tama ba?
    Nov 2003
    #53
    better to transtech it para makuha lahat pero if it's out of budget then drain refill will do naman.
    Oct 2007
    #54
    Thanks speedyfix. Ramdam rin ba sa performance ang shift to RP full-synthetic ATF from dino ATF? Kasi when I shifted to RP full-synthetic motor oil ramdam sa performance & fuel mileage - mas madulas & improved FC.
    Nov 2003
    #55
    shifting should be crisper. plus it will be able to take slightly more abuse and higher temps
    #56
    Bossing malapit na ako magpa-change oil plano ko sana sa shop nyo. Pwede rin ba ma-check sa shop nyo kung palitin na ATF ko? Am using a 1997 Toyota Noah Town Ace. Thanks.
    Nov 2003
    #57
    yup, you can bring it over any time to have it checked. thanks!
    #58
    Thanks. Punta ako weekend.
    #59
    Galing na ko sa shop mo last week at nakapagpachange oil and change ATF na rin ako. Your personnel there also fixed my problem on not shifting to low gear "L." I should say ok service sa inyo at ok din mga personnel nyo. Ang question ko lang regarding change ATF, ok lang ba na hindi na replace filter, magnets and the oilpan? Pinalitan lang kasi yung ATF at least three liters nagamit.
    Oct 2007
    #60
    it's ok to use dex3 on the tranny... drain it well and if possible do consecitive drain/refills to get all the dirty atf out.
    You mean I can use RP ATF on my 96 honda accord no problem? Have you actually tried it on this car? The manual says dexron II & RP ATF is dexron III. Just want to be sure. Thanks.
Best ATF for high mileage automatic transmission?
