Results 1 to 1 of 1
April 30th, 2014 08:13 AM #1
Good day friends!
Is the axle ratio going to change if you swap out the A/T from a different model vehicle? The stock axle ratio is 3.62, while the donor is at 3.79. I know it’s possible to re-gear RWD vehicles, but is there a way to mechanically change the axle ratio for a front-wheel drive vehicle?
If none, I’m thinking “taller” tires would be needed with the new transmission to compensate for this. There is a 3.71% difference between the stock wheel diameters of both cars (648mm vs. 668mm). There is no exact tire combo with the existing wheels to match the 668mm diameter. A smaller option is at 654mm (2.15% smaller) and the other is at 676.4 (1.21% bigger).
I’m inclined to stick with the existing wheels and the smaller tire option above. I know the speedometer/odometer would be off if I do this, but other than that, would anything else be compromised (engine, brakes, transmission, etc.) running with the smaller tires above, or would the difference be negligible?
Thanks in advance!
Production of the next gen Kicks confirmed .......
2025 Nissan Kicks
