Page 8 of 22 FirstFirst ... 45678910111218 ... LastLast
Results 141 to 160 of 440
    Jun 2012
    #141
    Any auto tranny specialist? Glxi lancer 93, problem is shift shock, pad nag D ako parang isang gear lng ang gumagana, tia more power tsikot. Im from valenzuela
    Nov 2003
    #142
    Nag back-read ako from page 1. Sa simula panay good reviews kay Bulaong, kaya papagawa sana ako sa kanya. Pero pag dating sa bandang huling page may bad review na, so nagdadalawang isip ako ngayon.
    Sa thread na 'to mostly Bulaong ang mga naka post na experience. Sa Baltak may naka try na ba?
    Jun 2012
    #143
    Quote Originally Posted by nic View Post
    Oo nga boss hirap mag decide, help mga gurus!!!
    Jun 2012
    #144
    Just to help lang po, if you have any transmission problems, check the link
    **************/index.php/view+classifieds/id/4248868/AUTOMATIC+TRANSMISSION+SPECIALIST+/+REPAIR
    as consumers mas ok ang maraming choices... to help out na din if you have questions just call or text, i will be more than glad to answer them to help you out ^_^...AUTOMATIC TRANSMISSION SPECIALIST
    Jun 2012
    #145
    Quote Originally Posted by transmissionboy View Post
    AUTOMATIC TRANSMISSION SPECIALIST - Engine Repairs and Service - Tsikot.Net Directory of Auto Shops and Services
    e2 po yung link, hope i can help you with your questions, glad to help ^_^
    May 2012
    #146
    mga sir for my comment naman regarding kila sir alex, mabait naman sila and mura maningil. lahat naman talaga ng mga mekaniko and kahit casa nag kakamali, and ang business talaga nila bulaong is surplus kaya ang ginawa ko last option ko na sila and ang good lang is nagawa nila kotse ko at 6 months warranty pa.. kung may doubt talaga kayo pwd nyo naman silang gawin na last resort na
    Jun 2012
    #147
    Ano pinagawa mo sir at ano oto mo and magkano
    Jul 2012
    #148
    Sirs, problem with at toyots camry 1988..but with same engine as tyota corona and first gen rav4. Sa inclined position or pag hanging..i need to use the hand break para di ako umatras..dati nman steady lng sya pag nkahanging ako.hasle for an at di ba. Nd pag malamig ung car, sa reverse or primera, parang nag i-slide sya,parang bumabalik sa neutral.any same xperience?nd san ko kya pde ipagawa.help pls.tnx
    Aug 2009
    #149
    good eveng, sir. saan ba pwde pagawa ng transmission? ung trusted and reliable? not expensive?
    my problem in the transmission. pag nakadrive tapos patakbuhin mo. tagal sya mag shift from 1st to 2nd gear. aabot pa 3000 rpm bago mag shift. pero mag init na ung makina. ok naman ung shifting. yun lang kung malamig pa at bago mag start. tagal mag shift at mahirap aakyat ng uphill (dahil sa shifting) pls help. thank you
    Jun 2010
    #150
    Quote Originally Posted by baby_scar View Post
    normal yan sa automatic transmission, kung malamig p at bgong start lng makina then uphill agad ang daan, hindi talaga magshift yan ng 2nd or 3rd gear, kumbaga walang salida...pero sabi mo n kelangan maabot muna yon 3000rpm bgo magshift, may problema talaga, nag-slide yon transmission...malayo kc difference ng auto at manual regarding acceleration, kung bgo start ang auto tranny n sasakyan, kahit itodo mo tapak sa gas, di yan magwawala , di katulad ng manual, pagbitaw m ng clutch, sibad agad..
    try to observation n bgo start ang sasakyan, dahan dahan lng to the max yon tapak, maramdaman mo kung nagsisihift talaga or hindi....saka refer to the manual, nakalagay doon kung ano rpm bgo magshift ang tranny....one more thing, like on my case n parang matagal magshift ang gear, check mo yon lever, be sure you will hear/feel click sound when from P to D or wherever, kc noon una, parang yan din problem ko, tagal magshift, then natuklasan ko n parang di masyado nakaengage yon transmission...(AT XUV Crosswind yon ride ko)
    May 2009
    #151
    swift a/t 2007 owner here.
    1st problem sa tranny if wot 1st gear indi sya nagshift to 2nd gear.
    2nd problem sobrang lakas ng shift shock pag D ang gamit ko but pag 3 normal naman.
    3rd problem 5 to 6km/ltr lang ako.
    san kaya pwede magpacheck?
    tia guys
    Nov 2012
    #152
    help pls i am looking-- auto transmission specialist repair shop--here in baguio
    my van is space gear 2000..any suggestion /comments/recommendation pls..txt 09189917827
    #153
    Quote Originally Posted by lukscudkil View Post
    tia guys
    when was the last time you changed your tranny fluid?
    san din location mo?
    Aug 2009
    #154
    mazda tribute 2005 automatic transmission
    , nagpa quote ako sa mekaniko sabi palit daw 40k++ surplas na part, taga ba presyo o ganon talaga presyo non?
    Pasig location ko po
    Jun 2011
    #155
    sino po marecommend nyo QC area? TIA
    #156
    Been having problems sa Reverse gear ko. Ayaw mag engage pero pag Drive gear walang kaproble-problema... Then I have read about this Trans-X thingy and been reading about good reviews with it on other forums... Yun nga lang wala akong makita dito sa Pinas kahit saan naghanap na ako mapa-Banawe or automotive shops sa Mall... Minsan Kamot ulo pa yung tinatanungan ko so I decided to order one Online...
    I already got it today.. It looks like this...
    I'll try this today and see if it works...
    Hindi naman kasi lahat tayo may ready money to pay para magpaayos ng Automatic Transmission (which costs an arm and a leg) so it would not hurt using this...
    I'll post feedback after a few days... Sana matapos na itong problem ko na manual na pagtulak ng sasakyan ko kapag nakapark facing wall...
    Mar 2011
    #157
    Help,
    bought a second hand ford focus 1.8 (2008)
    Yung Tiptronic hindi gumagana. wala naman problem sa P, R, N and D.
    hindi lang talaga nag-e-engage yung tiptronic
    Apr 2005
    #158
    Quote Originally Posted by X-isle View Post
    It's been a month and still no feedback regarding this product. Probably didn't work.
    #159
    Quote Originally Posted by Jo A. View Post
    Actually it did work! Its been more than 2 months and yep the Trans-X did work. At first paunti unti yung lagay ko since this was the first time ko maglagay ng additive that I have just known in the internet and quite hard or even close to impossible to find here in the Philippines.
    My automatic transmission is working like new! I still have around 250 ml left since paunti unti ko lang siya nilagay.
    The first 250 ml did not do anytthing, and then I did drove the vehicle around 10kms. Then I added another 250 ml so kalahating bottle na ang nailagay ko but still...
    Nawawalan na ako ng pagasa noon but still go for broke ako.. Drove it for around 15 kms after that.
    Then added another 250ml... Basta sinusunod ko lang yung panukat sa gilid ng bottle..
    Then drove it around 14 kms. Then after that 5 days ko siya hindi ginamit.
    On the 6th day sabi ko sa sarili ko itry ko muna before pouring in the last 250ml left...
    Started the engine, then aircon... Then usually when I put the car in reverse walang reaction yung sasakyan ko.. As in wala kelangan i-neutral at itulak since paatras palagi ako pag lumalabas from my parking space at home.
    But I was surprised. It jerked after 1-2 seconds and then proceeded to go reverse like there is nothing wrong!
    sabi ko sa sarili ko well not too bad mas ok kesa sa tulad ng dati na walang reaction whatsoever. So ok drove it for 14kms... (by the way I know its 14 kms since that is the usual distance from my home to NAIA since dun nagwowork si Commander GF hehe )
    Pagkapark ko pahinga for a few hours then I used the car and drove it again and yep reverse works fine this time wala nang delay. Siguro mga 0.5 seconds at magrereverse na yung sasakyan ko...
    After that I did not use the car again for the next 5 days. Then ayun no delay, no jerks, no nothing.. Smooth na yung automatic transmission ko.. :cheer3:
    Even my GF told me to order and stock up another bottle for emergency purposes... hehe natrauma na kasi siya noon na muntik na kaming hindi makauwi from a last full show since ayaw kumagat nung transmission. (tipong kahit anong tapak sa accelerator mag rev yung engine pero hindi siya gagalaw.)
    And yep if I'd be asked I'd certainly recommend this... Nothing hurts naman. For just around 500 bucks. Trans-X did save me from a 20K++ transmission overhaul...
    Naisip ko nga noon, since plano ko na din naman ipa-overhaul yung transmission ko, why not bite the bullet for 500 petot, masira man yung automatic transmission ko dun din naman ang tuloy sa overhaul... And yep Good thing I did try Trans-X...
    The only downside??? Well, Mahirap humanap dito sa pinas.. If you do find one here sa pinas papost na lang din dito sa thread... Mas tipid kasi since di ko na poproblemahin yung shipping from US to Manila...
    Lahat kasi ng tinanungan ko nito mapa-mall and mapa-banawe na auto shop Either "Kamot-ulo" or "Head Roll" ang binibigay sa akin... Partida pa at may Picture ng Trans-X ako na pinapakita sa kanila noon.
    So overall damage...
    500++ for the Trans-X
    800++ for the Shipping from US to Manila
    Equals a smooth Automatic Transmission. vs a 20K++ plus arm and a leg transmission overhaul which is either a hit or miss diba...
    Apr 2013
    #160
    gud eve,suggest ko sa store nmin Baltaks merchandise,you can contact us 4013611 or 4970087,look for leizel or Boss jun,we offer home service....depende sa napag usapan,tnx
Automatic Transmission Specialist
