Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
    you should have changed the atf at 20k 40k 60k 80k 100k 120k 140k..
    how many did you miss?
    Casa did not change my ATF at 20k
    mali ang tanong ko dapat 40k 80k 120k 😅
    Quote Originally Posted by Icis View Post
    Ok naman sir
    May nag recommend sa akin to change the solenoid?
    any suggestions for a specialist in transmission south area paranaque
    Either mali specs ng ATF or madumi na. Pde yata linisan shift solenoid, filter at magnet. Huwag mo pilitin umandar baka masunog torque converter.
    May 2018
    Good day.. im also having the same problem with my 2005 altis.. can you give me a trusted shop regarding this matter.. thanks!!
    Quote Originally Posted by miko101130 View Post
    dalin mu sa automatic transmission specialist.. i know someone if your interested... this is a flow of what to check,
    1.ATF ("correct specification" and amount) too much and too little is bad
    2.Electrical system of the vehicle especially the transmission (wiring, baka me loose connection or kulang sa ground etc.)
    3.mechanical portion ( shift lever baka stuck up/ cable going to tranny baka naiipit or meh nakaharang)
    after nyan at nandyan pa din problem, do a fault code scan ( code scanner OBD/ on board diagnostic)
    from that malalaman mo na kung anu error,, pag wala makita sa OBD( there are times na meh problem but not detected)
    4. transmission body check ( titignan na yung internals ng transmission mo including yung solenoid which controls the amount of ATF fluid to maintain hydraulic pressure. medyo madugo na ito at mahal
    just a note ilang kms na ang altis?
    and how hard is the altis being driven?
    nabaha ba unit?
    ilang beses ka na nag ATF change since nakuha mo unit?
    ATF change should be performed at 40,000kms
Altis Start Up Drive Problem : Delay in Drive
