Results 1 to 10 of 13
February 7th, 2020 06:11 PM #1
Hello Tsikoters, I was wondering if someone has experienced yung tunog na parang tomotope or tunog na parang diesel when driving from a standstill. Lumalabas yung tunog at 1K rpm and below. Pag past 1K rpm na, nawawala na sya. Same thing happens din pag nagdecelerate ka from say 2K rpm, lalabas ulit yung tunog pag hit ng 1K rpm. Wala naman yung sound pag P or N, or pagka naka manual mode. Car is a loaner for my wife sa company nila and has clocked more than 55K kms na.
Baka meron mga bros sa inyo naka experience nito. Kindly shed some light. Thanks sa mga sasagot.
Cheers!
February 7th, 2020 06:30 PM #2
February 7th, 2020 07:30 PM #3
- 52,698
February 7th, 2020 08:52 PM #4
- Aug 2008
- 142
February 7th, 2020 09:54 PM #5Knocking is normally caused by hot spots in your combustion chamber that ignite the air-fuel mixture before the spark plug fires. Could be the car was poorly maintained and has hot carbon deposits on the valves or cylinder heads...or you have spark plugs that have the wrong heat range. This is very bad for the engine and should be fixed ASAP by a qualified mechanic.
- Jun 2005
- 3,769
February 8th, 2020 09:54 AM #6Your vios comes with iridium plugs stock from the casa. Hopefully di pa pinalitan yan. It should last 100k kms (daw)
I will just change gas to higher octane or fill up elsewhere. Mukhang adulterated gas nakuha mo
Sent from my MI MAX 2 using Tapatalk
- 52,698
February 8th, 2020 10:45 AM #7
- May 2014
- 1,318
February 8th, 2020 02:59 PM #8Kung company car na kakaturnover pa lang to your wife, hopefully she can tell management na need tune up or check because of... (what you elaborated).
Re the cvt, nagcvtf change na ba yung vios?
And yung tanung nila re spark plugs, maybe need.
Though nakairidium, since traffic sa atin at madalas idling, baka... Baka lang may isa na pumalya na sa sparks? Pacheck na lang siguru to be sure.
Mahirap na masisi na kasalanan ng nagmana kung namana na may lamat yung kotse.
February 8th, 2020 03:22 PM #9
Dont tell service to change the spark plugs agad. That's an automatic cost to you. Have it inspected and shown to you. The stock plugs last long as they're mid tier. I'm guessing they're platinums.
February 9th, 2020 11:31 PM #10
It's looking like Shopee / Lazada / AliExpress have a long list of available parts for various...
2024 Manila International Auto Show APRIL 4-7,...
