Results 21 to 30 of 39
August 28th, 2009 09:59 AM #21
I guess it goes without saying that this is also where the driver's best judgment comes into play. There's no one correct answer but instead, it will depend on the current situation. Swerving to another lane that's occupied might cause more harm. You could fishtail, cause the other cars on that lane to abruptly change lanes themselves, which might create a chain reaction, or you could even collide with the other cars.
The best practice I've seen abroad in this case is that you tap on the hazard lights as you come to a stop... then pray the car behind you sees you in time.
Again, changing lanes abruptly (but controlled) to evade an obstruction on the highway is fine if the conditions are right. The point I'm making is to be sure you don't cause another accident doing so.
August 28th, 2009 11:20 AM #22
imho there are many variables to consider. for reference, here's the link to our traffic code.
August 28th, 2009 11:46 AM #24
August 28th, 2009 01:17 PM #26
boss try ko i-tagalog para klaro sa iyo.
hindi simple yung tanong at ang sagot ay nakadepende sa maraming bagay
halimbawa, paano na lang kung expired or peke ang lisensya ng bumangga sa iyo or ang lisensya mo? paano pala kung binangga yung kotse mo sa likod dahil nagt-text ang driver? etc. etc. etc.
August 28th, 2009 01:30 PM #27
Medyo bobo talaga ang traffic rules sa atin. Ako nga nakahinto tapos inatrasan nung nasa harapan ko, ako pa sinisingil kasi daw ako yung nasa likod at fault ko daw. Whaaat....hehehe.
Nung sinabi kong Php50k ang JAOS na bumper na inatrasan niya, ayun umalis. Pero parang siya pa galit.
August 28th, 2009 02:00 PM #28
August 28th, 2009 08:26 PM #29
August 29th, 2009 12:09 AM #30
Cabin Air Filtre Carbon activated, interchangeable with 27277-4JA0A/B P190 only. Almost P3k ito...
Nissan Navara NP300
