Results 1 to 10 of 19
- May 2005
- 215
November 17th, 2008 03:46 PM #1guys, I need your opinion on my innova. recently, I had my car checked at toyota because the check engine light indicator was on. they diagnosed a faulty EGR system (exhaust gas recirculation system). it was replaced and the light went off, however, i noticed after a few days that when my engine runs above the 2000rpm mark, no matter what gear I am in, I hear this loud hissing noise coming from the engine, I dont know if it has anything to do with the EGR system that was replaced. power seem to go flat at 2000 and hirap na umakyat ang rpm. Can anyone tell me what you think is wrong with my engine? thanks a lot.
November 17th, 2008 03:59 PM #2
hmm... another case of D4D woe?
i think you should bring it back to the casa for them to diagnose what is the cause of the problem.
November 17th, 2008 04:07 PM #3
i think it's the belts. have casa check on it. baka maluwag or sobrang hipit nung mga belts. hth
- May 2005
- 215
November 17th, 2008 04:13 PM #4puroy- no, i don't think so, i know the sound of a lose or tight belt, this one is coming from the engine. parang tunog ng may sumisingaw.
November 17th, 2008 04:19 PM #5
November 17th, 2008 04:24 PM #7
Usually at 80 KPH, I notice the turbo kicks in... it's also like a hissing sound. And you'll notice the power of the engine.
Di kaya yun EGR pa rin ang problem? Have it returned to casa, kuyapete so they could diagnose the problem.
November 17th, 2008 04:25 PM #8
you mentioned that you had your EGR system replaced, and that after 2000 rpm it seems to lack power. IMO it must be the turbo hoses, there is a leak somewhere. The power is lacking becuase the boost or air from the turbo is not fully going to the intake. The sound as you said singaw is the air from the turbo escaping somewhere. Have all the connection checked and the clips tightened.
- May 2005
- 215
November 17th, 2008 04:26 PM #9
- May 2005
- 215
November 17th, 2008 04:30 PM #10
Suzuki JIMNY [merged threads]
