Results 1 to 8 of 8
- Dec 2012
- 6
December 12th, 2012 03:15 AM #1Hi Guys,
Apologies in advance if my inquiry may seem ignorant in nature. I'm a total newbie when it comes to cars. If there's a similar topic to what I posted, then kindly direct me there. I would appreciate any assistance.
About a month ago, I had the chance to get my hands on a Toyota Corolla EE90. I believe they call it the "small body" in layman's terms. I'm pretty satisfied with the car itself. I got it at a cheap price and it's understandable that some parts are no longer as durable as they were intended to be. The first thing I did when I got the vehicle was to have the carburetor cleaned out and the oil changed. The mechanic also suggested to have the Air Filter replaced so I had that done as well. I also use the car in long drives (e.g. Laguna to Bulacan and back again) with no apparent problems. It was not until recently that I noticed a change with how the engine sounds. There's this distinct clatter or "kalansing" sound. I didn't notice it at first as there is no noticeable change with how the car performs. However, the sound can be heard as soon as I start the car. Based on my research, the problem may be caused by the following culprits:
- tensioners/timing belts
- piston ring
- bearings
- coins that may have fallen in the car's crevices
I just want to know what you guys think or if anyone already encountered a similar experience. Any feedback would be appreciated. If you also have an idea on how much repairs would cost, then that would help me out a lot.
Thanks
December 12th, 2012 08:35 AM #2
- Dec 2012
- 6
December 12th, 2012 08:58 AM #3The noise occurs as soon as I start the car. Regardless if it's just on idle or if I'm shifting gears. It's always there. :drive1:
I first noticed it when we were on our way back from a trip to Tagaytay. I heard the "kalansing" as soon as I started the engine. It was a distinct "tiny mild bell" sound. It can be heard from the driver seat, but I also checked from the outside. The sound became significantly louder once I had the hood opened. I think it's coming from the "cylinder block?" (not sure what that part is really called). Aside from what I enumerated earlier, I think I also read from somewhere that the culprit maybe the "barbula."
December 12th, 2012 09:20 AM #4
try running the engine without the accessory belts ( alternator, power steering, air conditioner belts) to eliminate the possibility of the forementioned accessory. the alternator cooling fan just behind the pulley is susceptible to damage from improper service procedure and does make a "tiny bell sound" when it makes unwanted contact with the pulley end frame of the alternator
- Dec 2012
- 6
December 12th, 2012 10:56 AM #5
- Dec 2012
- 6
December 14th, 2012 01:24 AM #6Hi again guys,
Just a follow-up to this inquiry of mine. I noticed that the sound disappears whenever I engage the A/C. Does that somehow isolate the issue to the A/C components?
December 14th, 2012 05:32 AM #7
you might have localized the noise source. try removing the a/c belt and run the engine to see if the noise disappears. while the belt is out and engine off, try turning the compressor pulley and the a/c belt idler pulley to further pinpoint the noise generator. check the belt if it needs to be replaced or if the belt shows signs of age or wear, change it
- Dec 2012
- 6
December 15th, 2012 03:46 AM #8
I also prefer silver. hindi halata na madumi na and some imperfections like faded color and slight...
